kyocera km 3035 toner is not supplied to developer
  • batabusiness
    • Sep 2015
    • 12
    hello, i sold one kyocera km 3035 to someone in another country, i can not make service to him , just by telephone i support him, he ordered toner, i sent to him toner not genuine , because i do not have in my country, now he complains that the copy is very bale , no contrast , he now add toner manually to the hopper ,cause toner can not leave the hopper is that from the toner is not seen by the sensor , or developer unit problem , in this model i can not see a program for forced toner as any machine on earth, so can you advice me with answer , thank you for help.
  • spree
    • Jun 2012
    • 211
    Re: kyocera km 3035 toner is not supplied to developer
    1.) Something wrong with toner - other profile (maybe in detail) or just because it is not genuine
    2.) When it is not genuine - there is other toner powder as in original (genuine) toner. You must change developer in developer unit, vacuum all old not genuine toner from the photoconductor unit and give there a new original (genuine) toner to the machine, and and than try to print.
    Some other ideas?
      • 23009
      Ok. Firstly the FalconII is a monocomponent developing machine. That means THERE IS NO DEVELOPER. Or it's all developer. Either way, the only thing in the developing unit is the same exact thing in the toner cartridge.
      Secondly, NEVER USE AFTERMARKET MONOCOMPONENT TONER in any machine that uses monocomponent toner. It produces inferior quality images, and tends to adhere to the surface of the developing roller. This is called "mottling". Yes it can be cleaned off, and yes it will immediately return.
      Thirdly make sure that you are getting Genuine OEM toner type A (370AB011), not Genuine OEM TK717 (1T02GR0US0) which looks almost identical, except for the toner feed coupler. The toner cartridges are not interchangeable, and the TK717 toner fill not feed out of the cartridge when inserted into a KM-3035.
      So to fix this you have to vacuum out all the aftermarket toner, clean the developing roller then rinse with alcohol, then insert Kyocera OEM toner type A (370AB011). Run simulation U130 to fill the now-empty developing unit. Once filled, you'll need to dry-wipe the developing cylinder with a dry clean cloth, until you get a nice smooth developing brush (no mottling). =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        I understand if you're limited financially or geographically to OEM toner, but yes, you need to at LEAST vacuum the dev unit out and try another generic followed by sim 130.
        • batabusiness
          • Sep 2015
          • 12
          thank you all for your advice , i will send him genuine toner and clean the magnetic brush , i am sure it will be allright
