Taskalfa 3050ci always shows A3 in preview window
  • taskalfa
    • Jun 2011
    • 97
    [Misc] Taskalfa 3050ci always shows A3 in preview window
    Has anyone seen this issue , im getting A3 displayed in preview window, if i place a4 paper on scan glass as soon as i close the adf is shows as A3, auto feeder is fine
  • Kyo fan
    • Dec 2013
    • 368
    Re: Taskalfa 3050ci always shows A3 in preview window
    Clean paper size detection sensors under the glass. May as well clean entire optical section while at it..
    • CWP
      • Jun 2013
      • 168
      Check the switch on the back right corner of the machine that the DP actuates when it is closed; I have seen them knocked out of position causing this issue. It is on the machine but the DP actuates it when closed.
      • Geo
        • 662
        You also may need to extend the length of the plunger activator.
        • taskalfa
          • Jun 2011
          • 97
          Replaced the pwb ISC and all is good, strange thing was if I disconnected the adf it would read the correct size off the glass, as soon as I plugged in the adf it would always read A3 of glass
