Copystar CS205C color supplies don't last
  • Bill Fla
    • Apr 2011
    • 12
    [Misc] Copystar CS205C color supplies don't last
    We have a Copystar CS205 Color machine and the color developer gets sucked out. I changed the Drums and Developers and they only last maybe 20K or less. The magenta developer is completely gone after 6k copies. I told the customer to make sure they change the toner when it needs it and not just reset it. It is supposed to last 200K. Any thoughts?
  • nathicana
    • Aug 2008
    • 330
    Re: Copystar CS205C color supplies don't last
    I haven't had the problem but take a look at this bulletin.
    Make sure the firmware is current.
    Do calibration and tone curve under system menu adjustment/maintenance.
      • 23006
      OEM toner? =^..^=
      • Bill Fla
        • Apr 2011
        • 12
        OEM toner? =^..^=
        Yes, we use OEM
        • sparkycivic
          • Apr 2017
          • 348
          check all waste toner passages for pluggage. also, look at the transfer belt waste exit to see if its plugged.
          plugged waste exit of the transfer belt will cause leftover toner to be on the belt, which screws up the self-calibration. then it tends to use a lot of toner due to the nfg calibration values, and more frequent calibration cycles.
          Is any junk waste falling on top of the yellow developer at machine front??
          • Bill Fla
            • Apr 2011
            • 12
            I ordered a new DV unit, I'll check the waste toner assy. then, thanks
