Kyocera TaskAlfa 5550Ci - non-printing side problem with some picture on it
  • spree
    • Jun 2012
    • 211
    Hello, I need help with this issue:
    When you copy or print in simplex mode (B/W or color) 2 copies, the second copy has at the NON-PRINTING side some picture from the first copy (see scanned image).
    What do you think, can happened this problem? I try to change drum (I swap the magenta drum (with charger roller) with black drum (witch charger roller)), but nothing happened.
    The copy machine has together B/W and color 126.000 copies only.
    I think, the problem can be at fusing unit, because the NON-PRINTING side has only contact with this. I think, the transfer roller can not be the problem, but... maybe, I think no? And transfer belt unit can not be the problem, because the NON-PRINTING side has do not touch with transfer belt unit (in simplex mode). Can I make some mistake in my idea? What do you think is wrong - fusing unit?
    Thank you for your help.
    • 23010
    Re: Kyocera TaskAlfa 5550Ci - non-printing side problem with some picture on it
    I agree with your conclusions. Maybe fuser, maybe 2nd transfer, not 1st transfer.
    If it's 2nd transfer you would see it mainly after a paper jam, or in smears if it's generic toner. If it's fusing, maybe the media type is incorrectly set too hot or too cold, either can cause toner to adhere to the heat roller then the pressure roller. =^..^=
      my bet a latent image is left on the press roller in the fuser.
      • spree
        • Jun 2012
        • 211
        Hello.
        Bad news. I tried other fixing unit and other 2nd transfer roller, but still the same :-(
        Example: when you print 3 copies (simplex) - all is good. Then you print other 3 copies (simplex) and only at the first copy at NON-PRINTING side is the picture. Then other 3 copies and only at the first copy at NON-PRINTING side the same.
        My idea: transfer belt unit do not perfectly clean the belt, this is transfered at 2nd transfer roller and this is the picture at NON-PRINTING side.
        You believe this theory is good?
        • protec
          • Feb 2005
          • 25
          Are you using regular plain paper and if not, have you set the media type in the driver and system menu to match the type of paper you are using?
          • spree
            • Jun 2012
            • 211
            Yes I change the media type from plain to heavy and still the same problem. I changed it in copy machine (in menu) and I make copies, no printing from PC. The paper is 80grams plain A4 format.
              • 23010
              You can do this: Make 10 copies of your red arrow test pattern. Switch original to blue arrow test pattern and make 10 more copies. Observe on the first page of the second set: what color is the shadow image? =^..^=
              • spree
                • Jun 2012
                • 211
                I test it like that: make some color copies, than make B/W copies and the NON-PRINTING side has color shadow image (at B/W copy). It is enough for you to help me? Otherwise I must go to customer
                • Kyo fan
                  • Dec 2013
                  • 368
                  Looks like transfer belt to me. Bring one with you if you have it.
                  • Geo
                    • 662
                    Not sure if this will help...I seem to remember we had a similar problem on a 3530ci. The drive/clutch pack for the transfer belt was slipping , a partial image would show up on the back end , lead edge. Replacing the drive resolved the problem. Also , let me throw this out...If the transfer roller isn't properly cleaning wouldn't the problem on the back end get progressively worse with a long run?
                    • spree
                      • Jun 2012
                      • 211
                      OK, this drive mechanism is that?
                      302LC94540 (2LC94540) PARTS TRANSFER DRIVE UNIT H SP
                      I can buy it, and try to change, if it help. (How terrible is to change it?)
                      • daveh12
                        • Jul 2012
                        • 157
                        Have seen what looks like a very similar issue, its was caused by non OEM Toner. The toner builds up on the secondary transfer roller causing the 'dirty' printing on the back of the paper, about 2 inches wide on the back of the leading edge side. What type of toner are you using?
                        • spree
                          • Jun 2012
                          • 211
                          Hard to say, but what I saw only genuine toners are used. And I changed the secondary transfer roller and it was the same (I think not so early the non-genuine toner builds to the "new" 2nd transfer roller), but I remember! When I stopped the machine, the picture was printed at NON-PRINTING side through 2nd transfer roller (the paper stops at 2nd transf. roller and it was there)!!! Do you think it is the transfer drive motor/clutch (302LC94540 (2LC94540) PARTS TRANSFER DRIVE UNIT H SP)???
                            what do you mean "nothing happened"? could you not make a print/copy? was there an error?
                            • spree
                              • Jun 2012
                              • 211
                              I want to detect the problem. I changed two drums, black to magenta and magenta to black and the problem exist farther. Yes I could make copy/print, no error, but the problem was still there - nothing changed, still the same problem - picture at non-printing side.
