TaskAlpha 3051ci broken LAN socket
  • copier tech
    • 8142
    [Electrical] TaskAlpha 3051ci broken LAN socket
  • Elmo
    • Feb 2010
    • 541
    Re: TaskAlpha 3051ci broken LAN socket
    I would say yes it is possible i have done several Ricoh's over the years
    i managed to buy a new nic socket off ebay
    it was a bit of a pain to get the old one off but it worked like a dream
    on the Ricoh i didnt need to back anything up
    Electroversal was a company in Luton who used to do board repairs at a good price
    not sure if they are still doing it i think they may have been taken over
    oops in my enthusiasm i didn't read your post fully thought you said you wanted to swap the nic lol
    I Used To Live To Fix Things Now i Fix Things To Live
    • CWP
      • Jun 2013
      • 168
      Yes, you should not have any issues swapping boards as long as you make ABSOLUTELY CERTAIN that you (carefully) pull the EEPROM off of the damaged board and move it to the board that you intend to use in the machine. If you don't move the EEPROM you run a good chance of creating a 3051ci boat anchor.
      • GeneOR95
        • Feb 2018
        • 161
        It should be a straight forward direct swap. Back up everything to a USP drive with maintenance mode U917 and put it in the new board after swap.
        • copier tech
          • 8142
          Thank for the info appreciate the help.
          I’ve read the service manual & will ensure I sawp over the roms etc.
          I will also back up as sugested with U917 is it the same U code to back up to the new board?
          The machine is on PaperCut is that going to cause me headaches or is that untouched on the HDD?
          • George J
            • 107
            Yup, board swap is the only way to fix this. (except for some mcgyvering)
            Swap the eeprom and the main pwb and it should work.
            Take back ups of everything when in doubt and print every report you can.
            (and follow the service manual steps )
            • copier tech
              • 8142
              Fitted a new board today, all good, thanks again.
