Time for Maintenance Kyocera 3500i & Triumph Adler DC2445
  • stern.detmold.32756
    • Feb 2018
    • 25
    Hello everyone,
    i have one Kyocera Taskalfa 3500i, which says "Time for Maintenance", also i have a Triumph Adler DC2445 with the same problem. Is there a possibility that i can erase this message without contacting Kyocera or Triumpf-Adler? And how?kyo maintenance.jpg
  • daveh12
    • Jul 2012
    • 157
    Re: Time for Maintenance Kyocera 3500i & Triumph Adler DC2445
    What count has the machine? Check the Preset Maintenance Values in MM U250. and reset in U251 if necessary.
    • linuxgyro
      • Oct 2012
      • 45
      I have seen this exact message before. It happens when you insert a high capacity toner into the machine if the firmware was too old. Upgrade firmware to the latest version and the message will go away by itself.
      • tech28
        • Jun 2013
        • 434
        High capacity toner for 3500i?
          • 23008
          What is the exact wording of the message. It's important. =^..^=
          • patrickjlc
            • Feb 2015
            • 225
            Originally posted by stern.detmold.32756
            Hello everyone,
            i have one Kyocera Taskalfa 3500i, which says "Time for Maintenance", also i have a Triumph Adler DC2445 with the same problem. Is there a possibility that i can erase this message without contacting Kyocera or Triumpf-Adler? And how?[ATTACH=CONFIG]39213[/ATTACH]
            Do a u251, clear maintenance counter. I do it every time I deliver paper.
            Sent from my SM-G930V using Tapatalk
              • 23008
              http://www.copytechnet.com/forums/ky...tml#post590669
              Kyocera 4500i PM message with 100k on machine
                • Feb 2018
                • 25
                I had both, normal and (T), it all worked perfectly like you said. If you have the problem "Maintenance cassette", do U251 reset too
