Kyocera Taskalfa 300i grey stripe on back of print
  • GOA
    • Jan 2017
    • 14
    Hello Techs!
    I'm having some trouble with one of our Taskalfa 300i units. The problem is that the prints come out with an ugly grey stripe/smudge on the back. The attachment will tell you more. If you have had similar issues please relate.
    With Regards,
    GOA
  • GESPAGE
    • May 2011
    • 40
    Re: Kyocera Taskalfa 300i grey stripe on back of print
    hello, you have found a solution ?
    Originally posted by GOA
    Hello Techs!
    With Regards,
    GOA
    • GOA
      • Jan 2017
      • 14
      Hello there!
      Unfortunately, no! We suspected there was poor contact between the high voltage panel and the transfer roller-neutralizing brush. We cleaned all the contacts, joinings, but to no avail. Also changed the transfer roller, drum unit+developer unit, also nothing. If you have useful advice concerning the matter, please share.
      • Step
        Senior Technician
        • Sep 2015
        • 42
        Two possible causes for the problem.
        1. Replace transfer charge roller
        2. Replace developer unit
        Make sure latest firmware installed.
        Sent from my SM-G935F using Tapatalk
        • GOA
          • Jan 2017
          • 14
          We changed both the transfer charge roller, and developer unit. Made no difference unfortunately.
          Please share if any of you guys have more ideas concerning this issue. Does anyone think the high voltage panel is worth changing too?
          Good day to you all,
          GOA
          • CleanTheSlitGlass
            • May 2018
            • 19
            GOA
