CS4052ci Dual Scan Error
  • JR2ALTA
    • Feb 2010
    • 2030
    Says cannot two side scan due to a failure. Saw a similar post here so I formatted hdd and reseated connectors.
    Event occurs with code C3210.
    906 will reset but returns every couple weeks.
    CIS not sold as a unit so I'm guessing at cis lamp,cis board and adf board.
    Any experience on this problem is appreciated
    • 22997
    Re: CS4052ci Dual Scan Error
    The Saturn series used quite a few CIS units. Initially the little 30mm CIS cooling fan would stall, allowing the CIS to overheat. I have no idea if any of this applies to your machine. =^..^=
    • Luther
      • May 2006
      • 682
      Make sure the CIS white roller is clean and upgrade the firmware
      • protec
        • Feb 2005
        • 25
        Remove the platen glass, clean the mirrors, lamp, lamp reflector and underside of the scanner and platen glass. The light from the lamp is faded because all or some of these are hazy or dirty.
        • JR2ALTA
          • Feb 2010
          • 2030
          Thanks all. I'm going back with cis sensor, cis board. Will clean thoroughly, although machine only 29k.
          I'll see if firmware released but current as of 2 weeks ago
          • protec
            • Feb 2005
            • 25
            OK. Correction. Had a brain fart and confused CIS with CCD. Luther has the right idea. Clean the CIS scanner glass, white roller(very clean) and update firmware.
            • Geo
              • 662
              Had the exact same problem , every 2-3 weeks coded ....Did the usual , Firmware , reseating connections, cleaning etc, no joy. Wound up replacing the doc feeder CIS and it's PCB (PWB SHD) , six months, no call backs.
              Cheers...
              • JR2ALTA
                • Feb 2010
                • 2030
                Cheers...
                That's good, as I replaced those today. CIS board held on by bullsh**t push pins. Darn near cracked the board getting it free.
                • Geo
                  • 662
                  Yep, the pins were a PITA..thanks for bringing back pleasant memories.
                  Just curious, when did it start coding , ours started shortly after installation.
                  • JR2ALTA
                    • Feb 2010
                    • 2030
                    Yea, within the first 10k at least. We've only had 3 codes but I knew it was time for parts.
                    • craigster
                      • Apr 2016
                      • 201
                      Not sure if you fixed this issue but we had the same issue and are fix was the CISC lamp sensor. Been trouble free since.
