Black Spots in one line (4555i and others)
  • stern.detmold.32756
    • Feb 2018
    • 25
    Hi everyone, i have a few copy machines that print spots in one line, everytime on the same spots on the pages. is it a drum problem maybe?2779.pdf
  • Kyo fan
    • Dec 2013
    • 368
    Re: Black Spots in one line (4555i and others)
    This is the main charger on Drum K. Take it out and give it good cleaning. If it's damaged, replace it. It's MC-8705 (302K993060).
    • itchyfinger@att.net
      • Oct 2017
      • 77
      measure the distance between the dots. then look at the repetitive guide in appendix and it will give you your answer
        i have found that you can use " Nu Finish " to clean the PCR.. it also makes the print bolder!
        • daveh12
          • Jul 2012
          • 157
          Charge Unit definitely, remove and clean, wipe dry with clean dry cloth afterwards. these charges are troublesome, check the surface of the charge roller for bumps while cleaning, if present replace the charge unit.
          • Ropariva
            • 673
            Originally posted by stern.detmold.32756
            Hi everyone, i have a few copy machines that print spots in one line, everytime on the same spots on the pages. is it a drum problem maybe?[ATTACH]39267[/ATTACH]
            Main charge rollers. They have a very high failure rate even on the new generation machines. Lucky to get 100k from them. The surface blisters and gives spots at approx 38mm intervals.
