Kyrocera Taskalfa 250ci Firmware - Error Code C7401
  • pwrmac7100
    • Apr 2018
    • 6
    I just installed the MK-865A maintenance kit for my Kyocera Taskalfa 250ci. After completing the upgrade, I got an error code C7401 when the machine booted. After some searching, it seems that the new developer unit requires firmware 11 or higher. Since I have the error, it appears I am older than that. Can you anyone put to me to the latest firmware (or at least 11)? I've been searching for a while and cannot find anything. The details of what I have are:
    Model: TASKalfa 250ci
    System Firmware: 2H7_2F00.006.043
    Engine Firmware: 2JZ_1000.010.004
    Panel Firmware: 2H7_7000.006.029
    Thanks in advance.
  • GESPAGE
    • May 2011
    • 40
    Re: Kyrocera Taskalfa 250ci Firmware - Error Code C7401
    Self diagnostic codes
    C7401 Developing unit K type mismatch problem
    Absence of the developing unit K is detected
    Causes : Developing unit connector inserted incorrectly.
    Reinsert the developing unit connector if necessary.
    Causes : Different type of the developing unit is installed.
    Install the correct developing unit.
    Thanks in advance.
    • aktasson
      • Feb 2017
      • 201
      Thanks in advance.
      Latest Firmware release notes.
      Version 16.24.0010 (2016-08-18)
      Release Date: 2016-10-13
      Main Frame Version
      Main FW 2H7_2F00.016.003 (NEW)
      MMI FW 2H7_7000.015.004 (NEW)
      OPTION LANGUAGE 2H7_81BR.001.034 (NEW)
      BROWSER 2H7_F000.001.016
      Engine FW (high) 2H7_1000.024.001
      Engine FW (low) 2JZ_1000.024.001
      Scanner FW 2H7_1200.005.002
      MOTOR Main 2H7_1400.003.003
      H VLT Main 2H7_1600.001.014
      SLEEP Main 2H7_1800.002.001
      DBA J00_E000.005.001
      • pwrmac7100
        • Apr 2018
        • 6
        Good to know. Do you know where i download it?
          • 23010
          You are at version 6.0 of the firmware from June of 2009.
          Yes the most current firmware is version 16 from April of 2018. It appears that version 11 does have major changes to developing.
          • Has Been
            • Nov 2012
            • 48
            Did you try sim 906?
            • pwrmac7100
              • Apr 2018
              • 6
              I have not tried anything, firmware or sims, but only because I cannot locate them. Can anyone send me a file link with the instructions?
                • 23010
                You may not have heard of it ... it's called the service manual.
                LMGTFY
                • pwrmac7100
                  • Apr 2018
                  • 6
                  Yes yes yes, I get the LMGTFY (personally I prefer RTFM - read the effin manual). I don't mind a good ribbing - but the firmware files are no where to be found. I'm just a lay person (not in the copier business), but I have spent hours searching the internet for the firmware. Kyocera's site only has manuals and drivers. I would love it you google'd it for me and sent me the link to the firmware files.
                    • 23010
                    You have to be a dealer to get firmware. Or hire a dealer that has it. =^..^=
                    • pwrmac7100
                      • Apr 2018
                      • 6
                      You have to be joking with that response - that was whole point of the thread! Telling me to read a service manual (which, btw, does not say anything about having to be a dealer)...life does not have to be this difficult. Just tell me "no" from the get go instead of having me jump through hoops.
                      For those reading this, google "TASKalfa250_300_400_500ci_15.24.0010_(2013-12-20).zip" and you will find a few sites hosting the file. This will not get you to the latest, but it at least will get you recent enough to overcome C7401 error. I would post the file, but after the last reponse I suspect that is against "the rules".
                      Lastly, if anyone happens to know the filename for the most recent firmware, please share so that we may fetch it on our own.
                        • 23010
                        You've got to upgrade to version 10 first:
                        TASKalfa Upgrade Pack 10.00 10-06-10 without Options.exe
                        TASKalfa Option Pack Ver 1.11 Firmware.exe
                        Then you can upgrade to any of the following versions:
                        Version 11
                        TASKalfa Upgrade Pack 11.00 1-4-11 without Options.exe
                        TASKalfa Option Pack Ver 1.12 Firmware.exe
                        Version 12
                        TASKalfa Upgrade Pack 12.00A 8-8-2011 without Options.exe
                        TASKalfa Option Pack Ver 1.13 Firmware.exe
                        Version 13
                        250ci 300ci Combined Firmware Upgrade Pack 13 5-10-2012.exe
                        Version 16
                        250ci 300ci Combined Firmware Pack 16.00.zip
                        The simple explanation is that on 10-06-2010 Kyocera split the Options off due to excessive file size. On 5-10-12 Kyocera split the firmware between Low: 250ci/300ci with options and High: 400ci/500ci with options. =^..^=
                        • pwrmac7100
                          • Apr 2018
                          • 6
                          great info. Thank you (seriously)!
                          For what it's worth, I already performed the upgrade prior to your last post. I did not make me upgrade to v10 first - as far I know everything worked. I have the new developer in without any errors.
                          Updated Info:
                          System Firmware: 2H7_2F00.015.005
                          Engine Firmware: 2JZ_1000.024.001
                          Panel Firmware: 2H7_7000.015.004
                          • GESPAGE
                            • May 2011
                            • 40
                            www.grosfichiers.com/0D3sAswkXvVHt
                            Disponible encore Fichiers:
                            firmware V.16 TASKalfa_250_300_400_500ci_16.24.0010_(2016-08-18).zip 109.4 Mo
                            Updated Info:
                            • Lordje
                              • Jul 2017
                              • 6
                              Hi, Would it be possible find this firmware somewhere, or can anyone share once more? I do have a problem with the scanner on my250ci, it makes a notice cannt use 2-side .. because of a fault. thx.
