km-4530
  • stevee104
    • Mar 2007
    • 214
    km-4530
    I have a machine that when you run about 10 copies 2or3 will have a light
    to blank line on them.It looks like the belts are stalling but i have change
    those out twice and i change the hold transfer section too.I change the
    paper loop timing and it has seem to help but any suggesting would be
    helpfull. Thanks steve
  • 10871087
    • Jan 2005
    • 1062
    Which way do the blank/light lines run (lead to trail or side to side) if it is side to side, how does the lead and trail edge registration look on the copies with the problem?
    What "belts" did you replace?
    • stevee104
      • Mar 2007
      • 214
      km-4530
      Its from side to side and i replaced all 3 of the conveyance belts,
      the leading edge looks okay.
      • mrfixit
        Senior Technician
        • Sep 2007
        • 83
        does the paper seem creased at all, this is a common problem on Sharps when the clutches get dirty the paper buckles.
        • stevee104
          • Mar 2007
          • 214
          KM-4530
          No it isn't creased but when you watch it come off the drum and it heads
          to the conveying belts it looks like it noses dive into the belts and
          that little bit causes the issue but as said before it doesn't do it ever copy.
          • Dukem
            Replace the corona housings or preferably the whole unit. Poor seperation will cause the paper to stick on the drum slightly longer and cause the 'nose dive'.
            • stevee104
              • Mar 2007
              • 214
              All ready change them twice with ones working form another machine,
              and also change the whole transfer unit.
              • xeroid
                Document Technologies Pro
                • 148
                Take a look at the mag brush on the developer housing. If you see fine lines you will need to carefully remove the trimmer bar and possibly the mag roller for cleaning. Be careful to reinstall the mag roller end bearings with the detent of the semicircle facing the drum above or expensive ruin of the drum could occur
                • Mark B
                  • Jul 2006
                  • 153
                  I have seen this, clean the bushings on the transport deck. Theyare slowing the belt down
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    Depending on the copies your machine has done - i would check the drive unit clutches. I had one do a similar thing (1million copies) every few copies a white line would appear. I stripped out the drive unit and stripped and flushed out the clutches as they all had heavy brown dust in them. It did cure my problem as the drive unit had never been touched because these are pretty solid machines.
                    Incontinentia Buttocks
                    • Absurd
                      Just a brick in the wall
                      • Oct 2007
                      • 118
                      Mark has it right I have seen this before also and the bushings had locked up and the t.belts werent always turning at the right speed.
                      Southern Duplicating of Mississippi
                      PSN: DrAbsurd (if you know you know)
                      "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
