TASKalfa 3551ci white copies in Bypass unit
  • correo.tony
    • 72
    Hi,
    we have a customer with a strange problem in a TASKalfa 3551ci, when select paper for the Bypass unit, the image is practically white,
    but if you take a duplex copy for the Bypass unit, the image is correct, rest of functions are OK ! copies for rest of cassettes are OK !
    It's crazy !!! we attach images, 1 copy 2 side for the Bypass and 1 single copy for the Bypass.
    Firmware version : 2N4_2000.007.031
    thanks in advance !
  • Ropariva
    • 591
    Re: TASKalfa 3551ci white copies in Bypass unit
    Originally posted by correo.tony
    Hi,
    thanks in advance !
    • correo.tony
      • 72
      Good morning Ropavira,
      thanks for your post,
      yes, the paper is new, Navigator A4 80gr extra, no humidity and is the same paper for 2 test copiers,
      thanks in advance !
      • itchyfinger@att.net
        • Oct 2017
        • 77
        just a guess but check your buckle adjustment for the bypass compared to the cassettes and paper type for the bypass
        • masterchill
          • Jul 2005
          • 100
          Did you check the paper type setting (thick ,plain,transparency ect...) ?
          • Dan J
            • Oct 2011
            • 25
            Had a similar problem recently, except that single sided from any source was fine, 2 sided - second side looked like your sample
            (very washed out). Ended up being the EEPROM on the engine board. New one programmed from Kyo solved the problem.
            • correo.tony
              • 72
              Thanks to all !
              Next week I'll prove to change the EPPROM,
              Bye !
