Ecosys M4125dn setup. Please advise on fax confirmation
+ More Options
Posts
  • axyun
    • Aug 2007
    • 1323
    Just st up M4125dn other day. Customer added fax option. Customer is strictly using as a copier and fax and will not be printing.
    Can confirmation page be set from system menu on machine or does this have to be done from dvd . Fisrt time setting up machine. Looked online for
    fax operation guide but not finding. Frank
    Re: Ecosys M4125dn setup. Please advise on fax confirmation
    not sure what you mean by this " Can confirmation page be set from system menu on machine or does this have to be done from dvd"
    if you haven't set the machine up via the instructions you better get them and follow them to a T
      • 30249
      System menu reports
      look for fax ,default is error only
      YouTube
      • axyun
        • Aug 2007
        • 1323
        Thank you Phil and bsm2. I went into the fax wizard setup as instructed butdid not recallanything about confirmations. i wll be going there today and
        go into system menu and take out of errors only default if this is what they want.
          • 23008
          I think that I would look at the Command Center. It's the easiest way to set almost anything on a Kyocera. =^..^=
          • axyun
            • Aug 2007
            • 1323
            I went into system menu and changed from default error only to "on" and okay now.
