Kyocera fs 6525
  • Gab
    • Aug 2015
    • 671
    Kyocera fs 6525
    MAchine has a 470 finisher with staples . 2 months ago it stops staplling. When i get in menu for sorting there aRE 4 IMAGES INSTEAD OF 6 . The two missing images are those for staplling. I checked staples and staple mechanism and looks fine . Any idea?
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Kyocera fs 6525
    Have you run a reset (906) in the maintenance/ adjustment menu?
    I learned a hard lesson that this reset has been moved from simulations to the regular system menu.
    http://www.copytechnet.com/forums/ky...ht=#post603366
      • 23006
      Re: Kyocera fs 6525
      There is no U906 on the Hanabi's. It's called "Enable Repaired Unit": System Menu/Counter > ^/v to Adjustment/Maint. > ^/v to Service Setting > ^/v to Enable Repaired Unit > Start.
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: Kyocera fs 6525
        Slow down. Read to comprehend.
        • sparkycivic
          • Apr 2017
          • 348
          Re: Kyocera fs 6525
          fs-6525 has no u906. "reset disabled unit" on models like this, is accomplished as per Black Cat's menu instructions.
          The finisher probably had a stapler jam or belt sensor error, and therefore will not offer to staple until the menu instructions are executed.
          • JR2ALTA
            • Feb 2010
            • 2033
            Re: Kyocera fs 6525
            Omg. Second guy corrects me for something i didn't say.
            • darry1322
              • Oct 2010
              • 817
              Re: Kyocera fs 6525
              The correction comes from this comment.
              • JR2ALTA
                • Feb 2010
                • 2033
                Re: Kyocera fs 6525
                I referred to the reset itself as a "906" because that's 10+ years of Kyocera vernacular. I clearly say it's been moved from simulations to the system menu. But who needs to read beyond the first sentence these days...
                  • 23006
                  Re: Kyocera fs 6525
                  Can we apply Occam's Razor for a moment?
                  Which do you think is the most likely? That your personal shorthand is inaccurate (at best confusing), or that everyone else is stupid/just wrong? =^..^=
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    Re: Kyocera fs 6525
                    Not everyone. Just the people who skipped past everything I said.
                    My second sentence was
                    Two people then interject to tell me I'm wrong: the reset has been moved from simulations to the regular system menu.
                    I even included a link that goes into great detail about it.
                    • Geo
                      • 662
                      Re: Kyocera fs 6525
                      Hi Blackcat...
                      I know this question is a bit off topic.... But ,if I may ask where and how did you learn about Occam's Razor?
                        • 23006
                        Re: Kyocera fs 6525
                        Originally posted by Geo
                        Hi Blackcat...
                        I honestly don't remember. It's like the first time you used the Pythagorean Theorem. It must have been 40 years ago, and I've used it almost every day since. It's one of those indispensable tools, that once you learn it you can't do without it.
                        How about you? =^..^=
