KM3035 many pages instead of 1 page
  • RandyW
    • Jan 2013
    • 213
    1 of our customers called up saying their KM3035 was print 10 or more sets of each page instead of 10 or more sets of each job.
    1 person I spoke with said it also did it on a Windows test page.
    I thought maybe it was a setting when getting ready to print PDFs but then they said it did it on the Windows test page too.
    I'm waiting to hear if maybe something changed with the PCs operating system perhaps. They have had the machines for quite awhile.
  • patrickjlc
    • Feb 2015
    • 225
    Re: KM3035 many pages instead of 1 page
    Install the drivers again, sometimes the windows update screws eith the printing queue
    Sent from my SM-G930V using Tapatalk
    • NeoMatrix
      Senior Tech.
      • 3513
      Corrupt spooler print job...?
      You may like to try resetting the print spooler directory on the offending PC.
      Example:
      Net Stop spooler
      Del C:\WINDOWS\system32\spool\PRINTERS\*.*
      Net Start spooler.
      You could try running the del spooler batch file from this old post....
      htttp://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/119238-mpc330-print-issue.html#post560818
      http://www.copytechnet.com/forums/ri...tml#post560818
      HTH
        • 23006
        Could it be as simple as the driver set to default to quantity (11)? It was fun (and easy) for the high school kids to default the HP printers to (50) prints of each print job. =^..^=
        • mntech
          • Aug 2010
          • 250
          I've seen this before with an incorrect print driver.
          IT person just renamed a konica print driver to kyocera because the IP was the same as machine was being replaced.
          Test page would work fine and only print 1 page, any other print job would spit out 10 sets.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            The industry doesn't exactly help.
            "KM" can either stand for "Konica Minolta" or "Kyocera Mita", making it easy to mess things up.
            We used to carry both, at the same time, and we had lazy people (in all departments) freely toss the term "KM" about. It caused all sorts of wonderful jokes.
