Kyocera M2540dw fax setup help
  • jper34
    • Sep 2011
    • 225
    Hi Folks,
    I'm delivering a new fax machine for customer, M2540dw, they want to be able to view received faxes , before actually printing them out.
    Can anyone help out with set up procedures..? Also, want to be sure it can be setup, to do this feature..Thanks !
    Jaime
    I.C.S.
    CT.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Kyocera M2540dw fax setup help
    forward to email is an option. There's nothing you can see at the machine.
      • 30200
      You can also forward to scan to file
      • Santander
        • May 2009
        • 768
        Originally posted by jper34
        Hi Folks,
        Jaime
        I.C.S.
        CT.
        You can setup fax forwarding via the machine's webpage or at the device though it is easier do it via the webpage, to have all incoming faxes forwarded to a folder as a PDF file. The user(s) then can preview the received faxes before printing from the folder assigned. On the fax tab set RX forwarding to on and then enter the information for the folder that you want to forward the faxes to, it is the same as setting up a scan to SMB. Just make sure that the folder size is not restricted as we have found that the users do not always delete the unwanted faxes or move or delete the faxes that they have printed, so a folder setup with a quota could easily be exceeded which will prevent new incoming faxes from being sent to the folder.
        • jper34
          • Sep 2011
          • 225
          Thanks Sand,
          Thats what I was thinking, has to be connected to newtwork, but I think this will work for my customer...thanks for the further instructions, really appreciate it !!!
          Jaime
          • Fountaingirl
            • Feb 2024
            • 2
            Thanks Sand,
            Jaime
            Clarification please: When setting it faxes to go to a file will each separate fax be a separate file/data item in the folder it is set to go in on the network?
            • ihatefinishers13
              Senior MFP Technician
              • Feb 2020
              • 694
              Yes, each fax job will be a separate file.
              • Fountaingirl
                • Feb 2024
                • 2
                Thank you!
