Orange Highlighter Not Copying or Scanning at all on new M8124cidn!!
  • chris@kokstadcopiers
    • Jul 2014
    • 14
    We have a client that owned a Kyocera FS-C8520MFP. They highlight stuff with different colour highlighters and then scan or copy them.
    We upgraded the machine to the new M8124cidn and for some reason it is not copying or scanning orange.
    It will just not show on the page at all as if it do not excist.
    If someone got any advice will much be appreciated.
    Attached is the old copier scans of orange highlighter.
  • CWP
    • Jun 2013
    • 168
    Re: Orange Highlighter Not Copying or Scanning at all on new M8124cidn!!
    Try turning the highlighter feature ON in original settings.
    • wild140
      • Feb 2017
      • 70
      Is the unit set to Auto Color ? try setting to Full Color
        • Jul 2014
        • 14
        It is set on Full Color. Did try to set sharpness, density, background density, just not picking up the orange.
          • Jul 2014
          • 14
          With highlighter mode on copy mode it comes out barely, but funny enough, no highlighter mode in scanning mode.
          Green comes out blue. If you scan the copied orange on the old C-8520mfp, and scan it on the new M8124cidn, it shows!
            • 22741
            Mostly you're noticing the difference between a color tabletop POS and a color copier. What were you expecting for #3K?
              • 22808
              ok what are the specs for this scanner?
              COPY
              Max. original size A3/Ledger
              Digital copy features Scan-once-copy-many, electronic sort, 2in1, 4in1, job reserve, priority print, program, auto duplex copy, split copy, continuous scan, auto cassette change (PF-470 or PF-471 is required), copy density control, Prevent Bleed-Through
              Exposure modes Auto, manual: 7 steps
              Preset magnification ratios 5 Reductions/5 Enlargements
              Zoom range 25 - 400 % in 1% steps
              Continuous copy 1 - 999
              Image adjustments Text, photo, text + photo, graphic/map, printer output
              SCAN
              File type TIFF, PDF, PDF/A, JPEG, XPS
              Scan features Integrated address book, Active Directory support, encrypted data transfer, multi send (e-mail, fax, SMB/FTP folder) at once
              Original recognition Text, photo, text + photo, optimised for OCR
              Max. scan size A3/Ledger
              Scan functionalities Scan-to-Email, Scan-to-FTP, Scan-to-SMB, Scan-to-USB Host, Network TWAIN, WIA, WSD scan
              Scan resolution 600, 400, 300, 200, 400 x 200, 200 x 100 dpi (256 greyscales per colour)
              Scan speed 40 ipm (300dpi, A4, b/w, colour)
              what are the scan settings at?
              clearly looking at these specs it SHOULD ( with all settings correct ) do what they require. NO I don't have a service manual to help you.
              can it scan color at all? ( sorry hit reply before I went back and re-read )
                • 22808
                COPY
                SCAN
                  • 27725
                  The answer has already been posted Kyocera's Can scan and copy in Color and pick up Highlighters. Plus you can custom adjust the density settings for normal as well as auto settings as well the type of scanning you wish ie text, text /photo, Ocr etc........
                  You can also set up a program key if needed.
                  we use to default our machines to text and would always give us darker ever-all image. Factory default is text/photo
                  you may also try the map setting
                    • Jul 2014
                    • 14
                    The answer has already been posted Kyocera's Can scan in Color and pick up Highlighters. Plus you can custom adjust the density settings for normal as well as auto settings as well the type of scanning you wish ie text, text /photo, Ocr etc........
                    http://www.impressionsolutions.com/s...OGR2017.10.pdf
                      • 27725
                      The big difference between these 2 models are the scan units. Yesterday we compared the two against each other and the color on the old unit scans perfectly. On the new M8124 it doesn’t pickup the yellow and orange at all. Yes, we did try changing color scan settings. Not impressed by the new M8124 at all.
                      Will upload the compared files.
                      there is also a vivid setting
                      and would use full color not auto
                      Many settings it only takes One to be off to screw it up
                      is
                      Prevent Bleed-through on or off?
                      Try the easy stuff first don't over think Kyocera's
                      full color
                      text mode
                      bleed off
                      density manual
                      One other kyocera trick any default change setting will require a reboot . Power off and on to take
                      affect.. Or you will see No change even if shows on display panel. IE changing default color to black panel will show black even on the web page but still scan in color until a reboot.
                        • Jul 2014
                        • 14
                        Update on the highlighter scan issue. We replaced the Kyocera M8124icdn with the M8130icdn and problem was solved.
                        The M8130icdn do have a CIS where the M8124icdn do not!!! Customer happy again.
