Copy star C307ci error 3101
  • digicor
    • Jul 2008
    • 1153
    I set scan to email up all the time, just did one of these last thursday, but today im getting this send failure 3101 check sender,receiver authentication protocol 's
    ?? any ideas? these are brand new machines, is there something i need to turn on? or off? (I have the smtp on duh)
    thanks for any info
    • 29947
    Re: Copy star C307ci error 3101
    Check port. IE 25, 465 586 or other
    Also does the email account require ssl or tls?
    Also must use full email
    If using gmail turn on less secure apps
    Auth set to other
    • digicor
      • Jul 2008
      • 1153
      thanks, i see what the trouble is, the sender name is not the same as the smtp auth log in name, but, i used a different sender name extension on the install thursday IE: escan@tampabay.rr.com/PW ****** Sender was admin@ lake apts.com...
      and it worked,hmmm, so i will change the sender name to**** @tampabay.rr.com... and see if this does it, again thanks
