Copystar X002i 4401 jam
  • oldtech1
    • Mar 2008
    • 35
    DU pulley shaft broke in half. All sensors, motors and clutches will test fine. Drove me nuts for a couple of hours. You have to replace complete right side transport/cover.
    • 23002
    Re: Copystar X002i 4401 jam
    Interesting!
    We got a bunch of Konica Minolta finishers (FS-528) that did something similar. The entrance roller was driven by a timing belt which was tensioned a little too tightly. The rear end of the shaft would break off at the rear frame/bearing within the first few weeks of placement. I believe that the person that installed the belt didn't trust the tensioner spring, so he/she put some additional thumb pressure on the tensioner. Of (50) machines I ended up replacing (40) of the entrance rollers. I let the spring tensioner tension the belt and it never re-occurred. =^..^=
