Kyocera Taskalfa 3500i/4500i/5500i Panel Issue Dead
  • fadsamniote
    • Apr 2016
    • 80
    Hello !
    Its the second time I have TK 5500i Copier , that both went to diferent customers and few days later the client call me saying that the machine doesnt show anything in the panel "Blank" but we can ear the printer working ...
    Allready search in Forum and everybody says that its the MAIN BOARD ...
    Can anyone send me by PM the Bulletin Technique about that ? (I heard in forum) and I have all firmwares but no Bulletin Techniques ...
    Regards
    • 23009
    Re: Kyocera Taskalfa 3500i/4500i/5500i Panel Issue Dead
    I don't know what this "Bulletin Technique" is. Are you asking how to load firmware? How to back up user data? =^..^=
    • Tonerkiller
      • Oct 2012
      • 668
      If I remember right. There was a problem with the main boards on the machines when they first came out, they came out with an updated board to prevent the blank screen from happening. There is probably a bulletin on this.
      • quitech
        • 82
        please friends, kindly help us for the bulletin code number if you have an idea.This problem is also affecting me seriously
        • nathicana
          • Aug 2008
          • 335
          You may have a loose connector. See step 14 in the attachment. The wide FFC cable can come loose from shock and cause this symptom. Be careful with the lock on the connector
          • fadsamniote
            • Apr 2016
            • 80
            Allready tried ONE PANEL from 100% working machine but no luck ... Still dead ...
              • 23009
              Did you attempt to load firmware after installing the op panel? I didn't think this needed saying, but you must re-load firmware when installing any Kyocera circuit board. It's a sure way to create a firmware level conflict when you install a board with a different level of firmware. =^..^=
              • masoom
                • Jan 2021
                • 2
                can you send me panel firmware.
                masom_68dk@yahoo.com
