FS-2035D, wow, ever seen this before?
  • Hansoon
    • Sep 2007
    • 3391
    FS-2035D, UFR just split in two pieces. Seems that the thermoswitch somehow catched the UFR
    Hans
    Re: FS-2035D, wow, ever seen this before?
    [ATTACH=CONFIG]40148[/ATTACH]
    Hans
    seen it all too often... Brother / HP / Samsucks ... they all do it after a while... doesn't help when the customer runs LTR manila envelopes W/ the metal clasps .... and then LIES about not doing it ( I found part of the tab causing jams in the 3RD fuser installed in 4 months. )
    • vee1989
      • Nov 2017
      • 34
      I also seen this happen alot before on FS-2100DN printers.
      • Blizzoo
        • Aug 2013
        • 610
        I confirm I've seen it once, forgot the exact model of Kyo but definitely a A4 BW printer.
          • 23010
          Very common on the Sharp facsimilie (the rollers are just too thin to survive the torque), and some of the Katun substitutes for Canon analog rollers (they were made of some kind of ceramic, and were known to shatter, usually breaking the heat lamps in the process). The Toshiba fuser rollers are so thin that very minor mishandling will dent them (I investigate any squashed boxes before I sign off on them).
          It's the price we pay for quick warmup times. =^..^=
            • 37558
            Got called out on a jamming problem the morning after one of our other techs had done a complete PM. Got there to find that a stripper pawl had embedded itself into the new hot roller.
            Last edited by slimslob; 07-28-2018, 06:34 AM. Reason: correct spelling of done(damned warn keytops)
