Task alfa 4002i exit fan/exit cooling
  • n25an
    • Jul 2008
    • 1030
    Need some help on this one...
    Here is the deal...
    I worked on a task alfa 4002i... I ran service mode 37 for a noise in the machine and troubleshooted it down to the
    Exit Cooling Operate the exit fan motor, the right container fan motor
    The problem is that I am looking at the service manual and I cann't find it... any help is appreciated...
    one would think... there would be a part called the exit fan or exit fan motor... but alas... that is not there...
    looking through the manual... my best guess is
    302K994350
    I am just checking if this is the right part???
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • granata
    • Jan 2012
    • 32
    Re: Task alfa 4002i exit fan/exit cooling
    it should be this code (ugly part list): 302fz94380
    • n25an
      • Jul 2008
      • 1030
      you are right... I got the wrong fan but... I found the problem when trying to put it in... the mesh on the outside vent was beginning to come loose and rub against the fan blade... hence the noise... taped down the mesh... noise gone...
