FS-4100/4200/4300 Fuser Pressure Cam part number
  • buzz
    • Aug 2013
    • 287
    The cam that turns to engage the lower fuser pressure broke off and for the life of me I don't see it in the parts manual.
    Anyone ordered these cams before from parts, got a part number?
  • kevin.coleman1
    • Mar 2017
    • 13
    Re: FS-4100/4200/4300 Fuser Pressure Cam part number
    I think you can only order a guest unit
    • kevin.coleman1
      • Mar 2017
      • 13
      Sorry, predictive text, I think you can only order a fuser unit
      • buzz
        • Aug 2013
        • 287
        the part is not in the fuser unit, the cams are in the main frame of the machine, beneath the fuser assembly.
        These are the 2 cams that need to be diverted in the downward position before installing a new fuser assembly (by turning machine on and allowing the motor to turn cams with fuser out of machine)
        In the parts manual REV 6, I see a part labeled "B" as a long shaft (rod) with an actuator for envelope mode but don't see the cams on the shaft on Page 10 (FIG 4). But awaiting confirmation if part is the right one.
        see attached
