C7104 TASKalfa 3252ci
  • kaborwen
    • Feb 2010
    • 146
    [Error Code] C7104 TASKalfa 3252ci
    Hi,
    I have C7104 on TASKalfa 3252ci (arround 126k), related to DV-Y TC sensor problem.
    After take out DV-Y unit, i find that there is no developer and toner inside.
    I know that I have to replace DV-Y Unit, but what can explain this. Is there an SB about this isue? If yes, please share it with me.
  • granata
    • Jan 2012
    • 34
    Re: C7104 TASKalfa 3252ci
    Reinstalling the developer unit The developer unit is not properly installed. Reinstall developer unit Y so that the connector firmly connects. Developer Unit Replacementand after control drive gear for developer unit Yand then Firmware upgrade.Good luck
    • kaborwen
      • Feb 2010
      • 146
      Thanks for replay.
      I reinstalled it several times. What i can't understand is how there is no developer and tonr inside DV-Y Unit?
      • granata
        • Jan 2012
        • 34
        The developer section consists of the magnet roller forming the magnetic brush, the sleeve roller forming
        the thin layer by replacing the toner, the developer blade, and the developer screw mixing up the toner.
        The toner density is adjusted by impressing the bias to the magnet roller and the sleeve roller. The toner
        amount inside the developer unit is detected by the toner sensor.
        • kaborwen
          • Feb 2010
          • 146
          Originally posted by kaborwen
          Hi,
          Please, someone have SERVICE BULLETIN or TECHNICAL BULLETIN about my case?
          Thanks in advance.
            • 23010
            Thanks for replay.
            This developing system is a little different from the others that you've seen. There will not be any developer or toner on the developing roller. =^..^=
            • granata
              • Jan 2012
              • 34
              [QUOTE=zanaty;2017271]
              It's impossible for the toner and developer to pop out from the unit
              it should be something wrong with the ID sensor under the Dev-Tank
              Or
              as been told, unconnected wires for sure bring the code with out of normal range reading for toner quantity
              exactly, I confirm everything that has been said by colleagues. Plus there is no technical bulletin on the case in question
              • kaborwen
                • Feb 2010
                • 146
                [QUOTE=granata;2017725]
                Inside DV Unit, there was no toner and developer powder.
                I replace DV Unit and all is ok.
                Thanks all!
                • granata
                  • Jan 2012
                  • 34
                  very good
                  • avio2
                    • Jul 2010
                    • 150
                    very good
                    wow un tecnico del toro di torino come me!!!!!!!!!!!! che posta qui poi
                    caso piu unico che raro
