Taskalfa 420i stuck on welcome screen
  • Mini Tech
    • Mar 2007
    • 17
    Hi,
    I have 2 Taskalfa 420i Machine which are stuck on welcome screen no memory Green light is blinking on penal .
    I have Check/changed the memory (on main board) on other machine and its working fine .
    Last i have solved this by changing the main PCB.
    Please guide how to handle this problem, if its firmware issue pleas provide the link to download.
    Best regards,
  • Tonerkiller
    • Oct 2012
    • 658
    Re: Taskalfa 420i stuck on welcome screen
    Most of the time this problem is solved by replacing the dim or memory stick
    • Mini Tech
      • Mar 2007
      • 17
      Dear Tonerkiller ,
      Thanks for your prompt reply .
      I have changed the Memory/Dimm but problem is still there.
      • Geo
        • 660
        Originally posted by Mini Tech
        Dear Tonerkiller ,
        If I remember correctly , a defective HDD can case this problem..
        • patrickjlc
          • Feb 2015
          • 212
          Don't you have to change both DIMMs? Mainboard and operation panel.
          Sent from my SM-G930V using Tapatalk
          • Scott
            • 185
            HDD
            • copier tech
              • 7930
              Any issues like this try updating the firmware first before spending 💰 on hardware
              • jper34
                • Sep 2011
                • 225
                I,ve seen the hard drive cause this issue.
