Copystar (Kyocera) CS 3035 Say "processing" when in print mode
  • Doug James
    • Jan 2012
    • 935
    [Misc] Copystar (Kyocera) CS 3035 Say "processing" when in print mode
    This copier is not being able to print to at all. Say "processing" and the light is staying on on the print button. I disconnected the LAN cable. with the machine off, turned it back on and the print light doesn't come on... The IT guy swears that there is no data going to it and assures me that he did everything on his end... I also did a u20 memory clear and screwed it up worse. Now the paper tray settings are off and the fax won't work. Any help would be very appreciated !!!
    • 23010
    Re: Copystar (Kyocera) CS 3035 Say "processing" when in print mode
    Oh yeah! This sounds like those lovely fax unit ribbon cables. Let's see if I can find the details:
    Can't access service mode. Can't download fax firmware. Can't access Fax Defaults in the System Menu (only the double beep). Can't access Fax Reports tab in the Fax screen (button grayed out). "Cover Open" indication when no covers are open. "Please Wait. Cannot be combined." when attempting to fax out. Ribbon cable from the fax control PWB to the main control PWB is damaged by removing the cable without releasing the clasp. Trim off the damaged end, or replace the ribbon cable (3CM27010).
    Oh, and doing an all memory clear was a really bad idea. For starters you'l need to set the destination to Copystar so it will recognize the Copystar RFID tags. Then when you get it running you can do all the electrical adjustments in the manual.
    Bad idea. =^..^=
    • Doug James
      • Jan 2012
      • 935
      Bad idea. =^..^=
      I figured I was in trouble after I did it. The bad thing is I know better... lol Getting to know the manual very well now...
        Bad idea. =^..^=
        TOTALLY A -=BAD=- idea.. RARELY use "ALL Clear" on ANY unit.
        • justanotherhack
          • Apr 2015
          • 74
          Upshot is, IT guy is wrong, something is trying to send something to that IP. Newer machines have a Data Capture simulation that can catch the bad print job and get rid of it, but I don't think that's available on that old unit. The only out is to give it a new IP address. Or sell a newer machine. Good luck.
          • JR2ALTA
            • Feb 2010
            • 2033
            Bad idea. =^..^=
            Are you sure you read his post? There's just something hitting that ip address, it works without network cable.
            If IT can't figure it out, just change the ip address to some other available #
            • jper34
              • Sep 2011
              • 225
              I'm not sure I recall this correct, but just a shot you can try..I believe I have to replace the control panel, I remember thinking it was odd, but I do recall that being the end fix. Has been a long time now, but that comes to mind, and if you another control panel to try..maybe..?
              Good Luck,Mate..
              Jaime
              I.C.S.
                • 23010
                I misread the post. I though it said that you still were getting a data light with the cable disconnected.
                Don't let these IT dweebs bully you. Just because they have an IT job doesn't mean that that know more than you do. I find it entertaining to have to explain some of these things to the folks that should already know them.
                • patrickjlc
                  • Feb 2015
                  • 225
                  If they allow you, go to one of their computers connected to the copier, and check their print jobs, one must be sending corrupt data.
                  As for the rest, do sim u252 set destination to US/inch. Then continue setting up the copier.
                  Sent from my SM-G930V using Tapatalk
                  • Scott
                    • 196
                    On many occasions we have proved IT wrong . MANY TIMES.
                    • Santander
                      • May 2009
                      • 768
                      If the unit works normally without the network cable connected, you definitely have a bad print job being sent to the unit. Remember that the Windows spooler will re-submit a print job good or bad once the unit is reset. Until you delete the bad print job from the computer/server print queue it is just resent and causes the same problem again and again! Most IT people have no clue as to how the print queue works and just blame the unit.
                        or after an hour and a half asking the IT just to give ME access to I can get back to MY shop before 1800hrs! and have it fixed.
                          • 23010
                          I don't have that argument anymore. You changed the password ... that's fine. You won't tell me what it is? that's fine. Let me know when you change your mind. =^..^=
