Kyocera 520i with black copies
  • copyaction
    • Oct 2007
    • 991
    This is the third time it has happened each time about 6 months apart.
    Each time I replace the main charge corona and the problem goes away.
    The cleaning motor is plugged in and charge cleaning is turned on.
    Today I installed a 5035 main charge corona as a test and works so far.
    Any other ideas?
  • patrickjlc
    • Feb 2015
    • 225
    Re: Kyocera 520i with black copies
    How many copies between the six months? They don't last long. I use the km-5035/5050 charge corona and it works. But eventually will give you black copies too.
    Only remedy is cleaning them every toner change, with a rag and cleaning solution. At leaat the older coronas are easier to take apart to clean.
    Sent from my SM-G930V using Tapatalk
      • 23010
      Charge loss on those FalconIII's is very common. Stock up on charge units. There isn't anything preventative to do. =^..^=
      • copyaction
        • Oct 2007
        • 991
        • copyaction
          • Oct 2007
          • 991
          On a related note will the drum unit from a KM3050 work in the 520i?
          I know they show different part numbers but I can't imagine they would be physically different and other than one rated for 400K and the other rated for 500K?
            • 23010
            The EEPROM is different for sure. It will code out. =^..^=
            • daveh12
              • Jul 2012
              • 157
              Km3050 Drum wont work on a 520i, but a KM5050 drum works just fine. and vice versa
              • patrickjlc
                • Feb 2015
                • 225
                Like BlackCat said, the 3050/5050 will give you a code, think is C7410
