SMB scanning
  • FWITIW
    • Oct 2017
    • 14
    SMB scanning
    Is anyone else having trouble scanning smb from a Ta 306ci? Two different locations, different operating systems, replace a machine that is scanning just fine with a new 306ci and the scanning won't work. One place still has a 3050ci with all the same settings that works just fine, put the same setup on the 306, no love. Both 306ci's have the latest firmware and "Use Temporary File Name" turned on. Any help would be great. TIA
    Re: SMB scanning
    look at the past threads ....
    do these machine have SMB1 or SMB2 ( my guess SMB1) you never mentioned WHAT OS the PC's are using ( win10 doesn't support SMB1)
    check the website to see if there is a firmware upgrade for SMB2 scanning
    • FWITIW
      • Oct 2017
      • 14
      Re: SMB scanning
      The computers are running win 7 and win 10. On the windows 10 machines, SMB 1 is turned on.
        Re: SMB scanning
        SMB1 is very problematic. look for firmware for SMB2 or 3
        SMB1 was disabled in win10 who the hell turned it ON?
        you run risk of virus infection and malware... WANNA CRY was the reason SMB1 was turned off.
        • mincopier
          • Dec 2015
          • 289
          Re: SMB scanning
          Here we go again.
          The TA 306ci is SMB V2 capable.
          Did you recreate the Address book or did you transfer it from machine to another using mode U917? You can export the one touch and address book to a USB drive, convert it using the Kyocera Setup utility, then import back into the new machine using U917. In this way all of the scan settings including the computer passwords are kept the same. If it worked on the TA 3050i it should work on the new TA 306ci.
          • frodo
            • Aug 2009
            • 36
            Re: SMB scanning
            What Send Error Code are you getting?
            • petermays
              • Mar 2017
              • 91
              Re: SMB scanning
              hi.
              only when a curtain update has been done on a win 10 os will the smb1 port be blocked.mine is still open and i have alot of users who is just fine.
              i do check up regulary or i just do the special firmware or setup FTP scan.less issues then smb scan
              • Up to date Tech
                • Jan 2018
                • 31
                Re: SMB scanning
                on win 10 when you share the folder only give access to that user not everyone
                • Up to date Tech
                  • Jan 2018
                  • 31
                  Re: SMB scanning
                  Originally posted by mincopier
                  Here we go again.
                  i tried to use this and did not transfer the passwords called tech support they they told me evrything will be transferred except the password.
                  from the 00 series it will but not 01 and 02
                  • Ropariva
                    • 694
                    • Up to date Tech
                      • Jan 2018
                      • 31
                      Re: SMB scanning
                      can you please send me the manual or video how to do it?
                      • Ropariva
                        • 694
                        Re: SMB scanning
                        Download and run this on your workstation.
                        • mincopier
                          • Dec 2015
                          • 289
                          Re: SMB scanning
                          Quick and easy FTP lite by Pablo Software works pretty good. Not as robust as Filezilla, but most user do not need the robustness of Filezilla.
                          Quick 'n Easy FTP Server Lite
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Re: SMB scanning
                            No need to run any other 3rd party FTP software. Microsoft Windows has local FTP and Network client access built into Windows Explorer.
                            Scan to FTP using a local NAS:
                            All in one I.T. Tech software.
                            htttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software-post694379.html#post694379
