dp 7110 dog ear/ folding
  • n25an
    • Jul 2008
    • 1030
    I have a task alfa 4052ci..
    the adf is dog earing on the long edge... leading edge... closest to the front...
    I checked the path and found no glue gunk or staples or labels...
    messed with the right hinge adjustment but can't get the dog ear/folding to go away...
    trying to get some ideas...
    any help is appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • Luther
    • May 2006
    • 682
    Re: dp 7110 dog ear/ folding
    make sure the white platen is installed correctly, take it of lay it on the glass and lower the df
    • n25an
      • Jul 2008
      • 1030
      i will give it a shot...
      thanks
      • JR2ALTA
        • Feb 2010
        • 2033
        Correct, if the platen mat is askew it impedes one or two of the gate flaps.
        • floody
          • Mar 2017
          • 37
          make a copy and crash it to try find the point to wheres folding the paper, does it make a noise when its going thru the ADF asif the paper is catching ?
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1889
            Bulletin H035 addresses the dog eared originals.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • n25an
              • Jul 2008
              • 1030
              after the paper passes the slit glass... it hits a section that has rollers and springs... and individual guides... one of the guides had a knick in it... It was towards the edge.... I smoothed it out... and swapped spots with a better guide and then applied scotch tape to it to make it smoother... issue resolved... since then I have worked on another kyocera task alfa with just rollers at that point where a roller fell out and the paper was jamming on the roller holder... I removed the roller holder which was at the left edge and issue resolved...
              to get to this guide remove the front plastic cover from the adf 3 screws from bottom 2 from top... it snaps off... then the guide usually is just two screws and slides out... it looks like the guide might have a some kind of attachment in the back... like a wire or such but never did... do your due dilligence just in case...
