fs-2100 f24(8) error code
  • tuey
    • Apr 2014
    • 120
    have one of these at an accountants office and it occasionally throws this code- i've never seen it but they say it's f24b which i think they are misreading and is f248. the manual has nothing but my research tells me memory error/corrupt print job with no known fix. anyone have any experience with this error? thank-you-- tuey
  • Ropariva
    • 671
    Re: fs-2100 f24(8) error code
    • Santander
      • May 2009
      • 768
      Follow the suggestions Ropariva made, this solves many of the F248 codes. We have also seen mal-formed webpages cause this code when the user tries to print it. Check with your user to see what they were trying to print when the code occurs. You may find that they were trying to print info from a webpage that was not constructed properly or contains malware. Had a case about a month ago where a user in a secure facility was trying to print a webpage that their IT dept determined contained malware causing the unit to lock up with a F248 code. Make sure you have auto error clear turned on, this will at least let other users to continue to print in a peer environment. If you have the driver on a server it may require the print admin to clear the offending job from the print server queue as the offending computer [user] is just going to re-submit the bad job until it is deleted.
      • tuey
        • Apr 2014
        • 120
        thanks , i'll let you know what happens. tuey
        • tuey
          • Apr 2014
          • 120
          does anyone know what is the most recent firmware version for this, and where i could get it?? thanks-- tuey
          • tuey
            • Apr 2014
            • 120
            updated firmware and it will now run 35-40 pages before coding out f248. it would code out before firmware at 4-5 pages. i'm on the right track but not fixed yet. has 1.3 gb of memory installed. they are printing quarterly tax documents. strange one for sure, i'm missing something. thanks--tuey
            • Santander
              • May 2009
              • 768
              Have you looked at the event log to determine if you are getting truly getting a f248 code or is it a f24b, big difference. The f24b code is an illegal access to the font cache [typically by the program sending the print job] to change fonts, it usually raises its ugly head on longer print jobs where there can be multiple fonts used in the document. Since you state that you have already updated the firmware, my next step would be to remove and re-install the print driver with the latest version making sure that the fonts are re-installed as well. Has the customer checked with the tax prep vendor for any updates? If you are getting a f24b error code, which I suspect, the tax prep software is trying to illegally change the font cache in the middle of the print job.
              • tuey
                • Apr 2014
                • 120
                wow, you could be on to something santander. it is a f24b code i believe, early on everyone else that i discussed this with said the B is not a B it's an 8- just hard to read. i'm gonna try and get in and check that, thank-you-- tuey
                • Ropariva
                  • 671
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    Clean out the PC print\spooler\ directory of any corrupt vector,PCL encoded files.
                    Reason for HTML PCL code print page fault:
                    Web page coders use copyright and printer protection algorithms in their web page HTML,PHP code to prevent users from copy and pasting or printing out their web pages. When a web user presses the print button on their browser to print out the web page, the page java script detects the print function and adds unwanted chars or oversized(infinite scale) vector font sets to bloat the printed pages with garbage, which scrambles the layout of output pages before being send to the printer.
                    Web page owners feel they have a right to copy protect their own work.
                    Of course Advert or Malware can do the same thing to HTML pages..
                    It is as it is...
                    You can convert the pages to XPS,PDF or manually screen copy and save each page as a raster graphic before printing.
                    HTH
