Kyocera M2535dn firmware or maybe another solution
  • Ricky965
    • Mar 2008
    • 36
    I have a machine that doesn't recognize the Fax Board. Tried another board and it didn't see it either. Any one help or do I need to update the firmware
  • kuby
    • Oct 2007
    • 1396
    Re: Kyocera M2535dn firmware or maybe another solution
    I don't know if the firmware would matter but it should be at v 11/17. What is the version on the machine?
      • 23003
      You should ALWAYS update the firmware when installing a board. What are the chances of you machine being at the exact correct/compatible firmware level as the boxed accessory or shelved part? Very slim.
      Updating the firmware avoids any and all firmware incompatibilities. =^..^=
      • Santander
        • May 2009
        • 768
        Is the machine truly a 2535 or did you put a fax board into a 2035? The main boards are different and the 2035 will not recognize the addition of a fax board and updating firmware will not resolve anything. If the machine started life as a 2535 then you need to replace the main board.
        • kola28
          • Jul 2012
          • 12
          how about the Interface Block-->Option I/F is it blocked?
          you can check it in staus page.(top right corner)
          • Ricky965
            • Mar 2008
            • 36
            It is a Kyocera M2535dn. The FAX option disappeared on it's on. It doesn't show in the setup or service modes. Was sent another card under warranty but it doesn't find it either.
            The I/F is unblocked.
            I believe firmware will fix it but I don't have it.
            • Ricky965
              • Mar 2008
              • 36
              I have all the firmware versions after I looked on my other PC, I believe the USB is disabled. It won't update firmware and Nothing will find the printer from a USB cord
              I must have other problems. How do you enable / disable USB
              • Ricky965
                • Mar 2008
                • 36
                Must be the main board. USB drive not recognized in the slot and it looks ok when I inspected it. Pretty sure they never used it. Oh well, time for a new machined. Thanks for all the ideas
                • Ricky965
                  • Mar 2008
                  • 36
                  Using Netviewer I see no software loaded for the FAX. Machine still copies and prints, returning it to the customer.
                  • tech07
                    • Aug 2008
                    • 409
                    Had 1 before. Exact same issue. Main board had to be replaced
