8002i fax system 12 not recognized
  • tech07
    • Aug 2008
    • 409
    [Electrical] 8002i fax system 12 not recognized
    new install. Machine recieved 40 faxes and no longer recognizes fax is installed. No 600 modes and device info page says NOT INSTALLED. The circuit seems pretty simple, fax modem, SSD fax "pony board" and main pwb.
    Obviously, I installed a new max modem without success and obviously I could just order another SSD board and main PCB, which I may do. But not being a parts thrower, thought i would throw this out there in case someone
    has "seen this before".......
  • Kyo fan
    • Dec 2013
    • 368
    Re: 8002i fax system 12 not recognized
    Before changing boards, try U021 and U002. After that, upgrade firmware to the latest.
    • CWP
      • Jun 2013
      • 168
      Make sure that the interface has not been blocked by checking device security in Command Center RX; sometimes IT blocks these for "security" reasons, not really knowing what they are.
      • Scottb
        • Apr 2013
        • 306
        also a fax simulator and a small brother fax to send and receive from will determine if it's the machine or a line issue
        • tech07
          • Aug 2008
          • 409
          Tried all suggestions in all above posts. The copier just doesn't know it even has a fax modem installed. I see no other option than to order a main board.
          Will update when solved.
          • tech07
            • Aug 2008
            • 409
            I try to post solutions to problems as much as possible.
            This issue was caused by main board.
            Hoping it was something less expensive, but this one is warranty
              • 23007
              That's unusual. I've replaced 3 or 4 fax options over the years for flakey operation or like you say, just disappearing. But never a main board. Thanks for posting back. =^..^=
              • sparkycivic
                • Apr 2017
                • 348
                I had a fax stop working, but on a 306ci. it turned out to be the FFC that connects the main board to the expansion bay wasn't seated fully in the connector. this cable is the same across most of the MFP models in circulation today, and is worthwhile to check before ordering part$. the fax boards themselves are practically bulletproof... as far as I've seen; and lightning is an issue in my area.
                • tech07
                  • Aug 2008
                  • 409
                  Yep. I started at the fax board and worked my way backwards. Definately main board.
                  • Scott
                    • 196
                    Thanks for the update, interesting
