FS 4000DN is working veeerryyyy SLLOOWWW...
  • Mizgal
    • Nov 2008
    • 16
    #16
    Originally posted by termacadon
    email me the file that you are printing.
    termacadon@gmail.com
    I want to test this.
    Done. You should have it on your email within few minutes.
    thanks
    Mizgal
    • skinnypuppy
      CopierJanitor/Geargluer
      • May 2008
      • 92
      #17
      Try forcing the network card on machine to either 10Mb or 100 Mb if this can be done. In other words take it off auto
      • Mizgal
        • Nov 2008
        • 16
        #18
        ive done this - it still stuck at 8.3 MB - than after few minutes at 11.6 - and more and more. it happend after my last changes. the situation didnt work when i enter old values.
        maybe this is an emprom problem or something?
        • termacadon
          IT goofball
          • Oct 2008
          • 66
          #19
          I had your document printed on my showroom machine and my adobe freezes when it get to finishing the file.
          Is it only this file? Try another one.
          • Warnock
            • Dec 2006
            • 50
            #20
            Slow Print
            Check your emulation. Take it out of PCL XL and go to 5. PCL XL is not backwards compatable with older PCL commands. Try KPDL also to see if you have a difference in speed. Also, make sure you are using the right KX driver, not the mini or universal. You should have a picture of your printer in the device settings tab of the driver.
            Programmers don't die, they gosub without return...
            • Mizgal
              • Nov 2008
              • 16
              #21
              Ok - it work .
              for VISTA 64bit here is what i did:
              - uninstall AVAST (install COMODO INTERNET SECURITY in that place)
              - turn off DHCP in QNAP server in our network.
              - turn off printer share - on each computer its works now like LOCAL
              - update driver with full instalation (big package from KYOCERA 44.9MB)
              - PCL XL (almost all options are DEFAULT in the new driver)
              and thats it
              the same for XP's PRO.
              and it still works.
              after few hard weeks...nerwous nights...hard call with my super-service guy that they wanted me to believe that this is NOT ORIGINAL TONER issue...i can finally get back to business...
              thanks a lot to you all guys. your ideas was great - thanks for you time and patiente.
              see you
              Mizgal
              • KyoSpec
                #22
                Possibly RAM Disc issue
                Considering you only have 128Mb memory, having a ram disc size of over 90Mb is quite excessive, the problem with only 30MB of remaining memory is there is not much space to process the print job. Reduce the ram disc size through the menu in the machine and in the Device Settings section of the printer driver. (ensure they match)
                Ideally having additional memory would help if you would like a larger ram disc allocation, otherwise purchase a HDD option.
                The only time a ram disc/HDD is useful is when you are printing multiple sets of a resonably large file, if you are not switch it off in the driver as well as in the menu of the machine.
