TASKalfa 3051ci developer or drum issue
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Hi,
    User sand me a sample.U89 A3 format.
    I read about 3051ci problems with developers.
    It seems to me like a drum. The copier has 140K.Reviews please. Thanks.
  • Has Been
    • Nov 2012
    • 48
    Re: TASKalfa 3051ci developer or drum issue
    Originally posted by zoraldinho
    Hi,
    Dirty Magenta Charge roller
    • itchyfinger@att.net
      • Oct 2017
      • 77
      agreed dirty charge roller clean all 4 of them while your in there and vacuum out the cavity. if you see blisters in the roller while cleaning it, replace it with the new style.
      • craigster
        • Apr 2016
        • 201
        Definitely charge roller!! after cleaning it do a laser clean also
        • drazen7777
          • Sep 2010
          • 40
          Hy to all
          I would like to hear whats yours cleaning solutions for chargers ? Iuse some kitchen cleaner called Meglio , thats prooved for me as the best result in charger cleaning and removing dirt but i think it leaves some film of product after wiping it off , so i wipe with alcohol after. If i try with alcohol only it is hard to remove stuck dirt on chargers.
          Technician -- a person who fixes the mistakes made by engineers.
          • darry1322
            • Oct 2010
            • 817
            Originally posted by drazen7777
            Hy to all
            Damp cloth with plain water.
            • ntbann
              • Jan 2012
              • 628
              Agree. Water on a cloth works the best. Don't use alcohol. It deteriorates the rubber.
                • 23009
                For years I've been using automotive washer solvent. Today I tried straight water and it works even better.
                • Has Been
                  • Nov 2012
                  • 48
                  Unscented Baby Wipes
                  • Dan J
                    • Oct 2011
                    • 25
                    Replace or clean the charge rollers.
                    Hi,
                    • Geo
                      • 662
                      Once , during my experimental phase I used hand sanitizer..did a great job cleaning, but a small dab was accidentally left on the roller for about 5 minutes. Cleaned it so well that the coating peeled right off.
