FS-6530MFP--FAX SYSTEM U Does not communicate --make dail tone noise pressing on hook
  • JeffMills
    • 22
    [Misc] FS-6530MFP--FAX SYSTEM U Does not communicate --make dail tone noise pressing on hook
    Customer had power issues now faxes will not come in or send you can see green lite and processing will give busy confirmation sheet. I did try macchine and cord on/off and sim u601 and u605 any other ideas?
  • etaylor
    • Sep 2016
    • 7
    Re: FS-6530MFP--FAX SYSTEM U Does not communicate --make dail tone noise pressing on
    Is there another fax machine in the office? I had one the other day, they have 2 faxes and I didn't know that but they would both pick up and it was conflicting. So, I had to change one to 4 rings while the other one was 2.
    Sent from my SM-S906L using Tapatalk
    • Santander
      • May 2009
      • 768
      If this started after the power issues, have you tried dialing the fax number and hear what is going on with incoming faxes? It may be that the phone line is the problem. Turn the machine off and call the fax number, what occurs? Had a major customer a month ago call claiming the fax was dead after power issues in the building, turned out their pbx had blown the line card for the fax.
