Kyocera M5526 Printing half speed
  • Drumluck
    • Oct 2017
    • 5
    [Misc] Kyocera M5526 Printing half speed
    I have a Kyocera M5526 All in One, Printing and Copying half speed. Normal Speed is 26 pages per minute, but this machine is no more than 15 CPM. Problem just started recently I have upgraded the firmware and checked other simulations. The machine has only 48000 prints, and I have checked others and they are running at normal speeds.
    Any help would be appreciated.
  • darry1322
    • Oct 2010
    • 817
    Re: Kyocera M5526 Printing half speed
    Printing on media types like thick and cardstock will slow print speed. Also quiet mode will slow the speed.
    • Geo
      • 662
      Did you check the setting for quiet mode?
      • kuby
        • Oct 2007
        • 1396
        Geo is right, quiet mode slows down the copier.
        • guitar9199
          • Sep 2016
          • 1100
          Just for giggles, check and see if the print driver is set for "2-sided".
          • JR2ALTA
            • Feb 2010
            • 2030
            Envelope lever engaged?
            • tmaged
              Owner/Service Manager
              • 1869
              On the 2626mfp, the spring would come off the paper feed unit & it would cause this. The machine would not go to a jam code, but kept trying to pick up paper until it was successful. Something to look for if you media is set to plain.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • Tonerkiller
                • Oct 2012
                • 668
                My guess is that tires are worn.
                • Scott
                  • 195
                  media type is my guess
                  • JR2ALTA
                    • Feb 2010
                    • 2030
                    Now it's up to drumluck to post the solution and pay the winner.
                    • kuby
                      • Oct 2007
                      • 1396
                      Also if the resolution is set to 1200x1200 it will reduce the speed.
                      • Drumluck
                        • Oct 2017
                        • 5
                        It seemed to be that the quiet mode was on.
                        • Geo
                          • 662
                          Yee Haaa ..I finally got one right....
                            come on Brother... you have a higher score in my mind... some may not admit it ..
                            I try to give credit when it's due... But I also will blast someone when they aren't providing proper info...or refuse to TRY/take suggestions..
