ECOSYS M6030cdn Black Stripes
  • kyove
    • Apr 2015
    • 62
    Hi Guys,
    I have problems with a M6030cdn. Here is a status report.
    Laser seems to write the correct image but.. i don't know. Developer problem? Transfer problem?
    Or maybe an engine board?
    Machine is set to print in bw but if I set color mode there are stripes of other color.
    What do you think?
    Kyove
    Re: ECOSYS M6030cdn Black Stripes
    Originally posted by kyove
    Hi Guys,
    What do you think?
    Kyove
    check the contacts on belt-drums-devs...
      • 23010
      The black developing cylinder is arcing to the black drum. If you happen to be doing color when it happens you'll also get bands of C, M, & Y. You're just lucky that it's black, so you can isolate it.
      Replace the black drum and developing unit, and do a color calibration. =^..^=
      • gabrielduron
        • Nov 2018
        • 4
        something similar happened to me, just remove drum and developer unit and reinstall it again and voala! worked!, hope its a minor problem and can solve it!
