HDD Drives
  • Geo
    • 662
    HDD Drives
    Greeting all
    Has anyone tried and been successful in formatting and re-purposing HDD for DOS based computers..If yes , how , please provide details .
    Thanks much....
  • Ropariva
    • 669
    Re: HDD Drives
    Originally posted by Geo
    Greeting all
    Thanks much....
    Yes. They are just plain Jane HDDs
    • Ctl-Alt-Del
      • Jul 2006
      • 430
      Re: HDD Drives
      They almost always format fine but tend to be on the smaller side so I usually don't have a need for them.
      • mincopier
        • Dec 2015
        • 289
        Re: HDD Drives
        As mentioned they are usually standard HDD's and can be formatted on a PC for use in a PC or Mac. Also as mentioned depending on the age of the copier they tend to be on the smaller side. I have acquired a couple terabyte HDD's that would not work in a copier but are fine in a computer. Even a 320Gb or 500Gb drive is not bad to use for backup for files on a computer.
        • Geo
          • 662
          Re: HDD Drives
          Well I have a bunch of 250 gig and I can put them to use and my frugal (cheap) side doesn't/cant want to throw them out. As for formatting, just use an external reader and do what type of format?
          • NeoMatrix
            Senior Tech.
            • 3513
            Re: HDD Drives
            Here's a batch file to Wipe clean any old working HDD.
            This does a factory reset of the HDD back to an UNINITIALISED drive.
            I wrote this in a hurry this morning, I haven't fully tested it on an old HDD.
            Some one may like to test the below batch file on an old drive.
            Cut and paste the below to a text file named "CleanHDD.bat"
            -----------------------------------8<------ -----------------------------------------
            echo off
            rem Hard Disk Drive Clean. Reset HDD to Factory Uninitialized.
            Rem Useage: CleanHDD /Secure = factory clean.
            rem Author NeoMatrix, www.copytechnet.com
            rem Date:5-12-18 Ver1.0
            setlocal ENABLEDELAYEDEXPANSION
            Set "ErrorFlag="
            set "Star="
            for /L %%S in (1,1,49) do set Star=!Star!*
            set "Line="
            for /L %%S in (1,1,80) do set Line=!Line!-
            set "Param="
            if /i "%1"=="/Secure" set Param="All"
            rem -------- Main flow ------
            :Main
            cls
            Call :Header
            Call :HDD_Info
            Call :SelectDisk DiskNo
            Call :Prompt Action
            Call :WipeHDD %Action% DiskNo Error
            Call :Footer %Error%
            goto End
            rem ---------- Header -----------
            :Header
            echo **************** Hard Drive Clean ****************
            echo **** WARNING ALL HDD DATA CANNOT BE RECOVERED ***
            echo Usage: CleanHDD.bat [switch]
            echo Example : CleanHDD
            echo CleanHDD /Secure
            echo *** CleanHDD must be Run as administrator only.***
            echo %Star%
            exit /B
            rem ---------- HDD Information -----------
            :HDD_Info
            (echo rescan
            echo list disk
            echo list vol) | diskpart
            wmic diskdrive list brief
            echo %Line%
            exit /b
            rem ---------- Select disk -----------
            :SelectDisk DiskNo
            set /p DiskNo="Select Disk, Enter number >"
            set %1=%DiskNo%
            rem (echo select disk %DiskNo%) | diskpart
            echo.
            Exit /B
            rem ---------- Prompt -----------
            :Prompt Action DiskNo VolumeNo
            choice /C YNC /M "Totally Wipe Clean Disk:%DiskNo%"
            if %ERRORLEVEL%==1 set Action=Prompt
            if "%Action%"=="Prompt" (
            choice /C YNC /M "HDD clean CANNOT be recovered, continue..."
            if %ERRORLEVEL%==1 set %1=Wipe
            Exit /B
            rem ---------- Wipe HDD -----------
            :WipeHDD Action %DiskNO% Error
            if NOT "%1"=="Wipe" exit /B
            if /i %Param%=="All" (
            echo HDD Secure cleaning mode will take some time...
            echo.
            rem -- CRITICAL SECTION --
            (echo sel disk %DiskNo%
            echo clean %Param% ) | diskpart
            rem diskpart fails to set errorlevels.
            set %3=%Errorlevel%
            exit /B
            rem ---------- Footer -----------
            :Footer Action
            echo Finished cleaning....
            echo %Line%
            echo HDD is now Wiped Clean.
            echo All HDD Partitions and Formatting removed.
            echo HHD is factory default UNINITIALIZED configuration.
            echo.
            exit /B
            rem ---------- Exit-----------
            :End
            endlocal
            echo Hit any key to continue...
            >nul timeout /t 10
            • NeoMatrix
              Senior Tech.
              • 3513
              Re: HDD Drives
              Bug fix... sorry to those.
              I accidentally copy and past the debug 1.0 version of the batch file.
              The below updated version will reset USB thumb drives and /SD cards as well.
              --------------------------- 8<----------------------[Ver.1.1]-----------------
              echo off
              rem Useage: CleanHDD /Secure = factory clean.
              rem Date:5-12-18 Ver1.1
              rem Secure Cleaning mode can take some time ,Example:
              rem A 2GB USB thumb drive and take 10-15min to clean securely.
              set "Line="
              for /L %%S in (1,1,30) do set Line=!Line!-
              set "Param="
              if /i "%1"=="/Secure" set Param=All
              set "T= "
              set "TTT= "
              set "Action="
              Set "Error="
              rem Set wait time here before total wipe.
              set /a CountDown=6
              :Main
              cls
              Call :Init Error
              If DEFINED Error goto End
              Call :Header
              Call :HDD_Info
              Call :SelectDisk DiskNo Error
              Call :Prompt Action
              Call :WipeHDD %Action% %DiskNo% Error
              Call :Footer %Action% %DiskNo% %Error%
              goto End
              rem ---------- initialise -----------
              :Init Error
              set exepath=%comspec:cmd.exe=diskpart.exe%
              set "%1="
              If not Exist %exepath% (
              echo Microsoft diskpart.exe not found...
              set %1=1
              exit /b
              :Header
              echo -----------------[ Hard Drive Clean ]--------------------
              echo * %T% WARNING ALL HDD DATA CANNOT BE RECOVERED %T%*
              echo * Usage :CleanHDD.bat [switch] %TTT%*
              echo * Examples: %TTT%%TTT%*
              echo * %T%CleanHDD %TTT%%T%%T%*
              echo * %T%CleanHDD /Secure%TTT%%T%*
              echo * CleanHDD must be run as Administrator only.%T%%T%*
              echo * DO NOT add/remove USB drives while running CleanHDD %T%*
              echo * %T% Press Ctrl-C to Break. %TTT%*
              echo --------------------------------------[Ver 1.1]----------
              exit /B
              :HDD_Info
              set "DeviceNo=0"
              ( echo rescan | diskpart ) | Findstr /b /v /i "Diskpart Copyright On computer"
              for /L %%i in (0,1,25) do (
              echo HDD Device :[%%i]
              (( echo select disk=%%i
              echo detail disk ) | diskpart | Findstr /L "Device Volume" ) || exit /b
              echo.
              exit /b
              echo End of drive search.
              echo.
              echo ------ User Input -------------%Line%
              set /p Dn="Select HDD Device, Enter number >"
              set %1=%Dn%
              echo -------------------------------%Line%
              echo.
              ((echo sel disk %Dn% ) | Diskpart) | (findstr /i /L "not valid") && set %2=2
              exit /B
              choice /N /C YNC /M "Totally Wipe HDD Device:%DiskNo% Y/N/C? >"
              if not %ERRORLEVEL%==1 exit /b
              choice /N /C YNC /M "HDD Device:%DiskNo% CANNOT be recovered, continue...Y/N/C? >"
              exit /B
              :WipeHDD Action DiskNO Error
              if "%Param%"=="All" (
              echo HDD Secure cleaning mode can take some time...
              echo.
              echo ...Ctrl-C to break...
              rem echo ...ready to Wipe drive %2.
              timeout /t %CountDown%
              (( echo sel disk %DiskNo%
              echo clean %Param%
              ) | diskpart ) | Findstr /v /i "DISKPART> Copyright On computer"
              rem Error not used.
              set %3=%Errorlevel%
              exit /B
              :Footer Action DiskNo Error
              echo.
              if not "%1"=="Wipe" exit /b
              echo %Line%%Line%
              if "%Param%"=="All" Echo Secured Cleaning Mode done...
              echo HDD Device:%DiskNo% should now be Wiped Clean.
              echo HHD set to factory default UNINITIALIZED configuration.
              echo.
              exit /B
              :End
              endlocal
              echo Hit any key to exit...
              >nul timeout /t %CountDown%
              • NeoMatrix
                Senior Tech.
                • 3513
                Re: HDD Drives
                Re. CleanHDD.bat file.
                If I get enough time and enthusiasm I may knock up another batch file to complement the CleanHDD.bat.
                The batch file will rebuild the partition tables and format the factory reset drive done by CleanHDD.
                The PartHDD.bat file should be able to do MSR EFI,GPT ,MBR,multiple partitions.
                Plus partition formatting file systems, FAT,FAT32,NTFS etc....
                It will do USB,SD-Card, HDD,SDD devices.
                I'll see how the enthusiasm pans out....
                • Geo
                  • 662
                  Re: HDD Drives
                  Thanks much for your impressive post and knowledge...Haven't time to try this, hopefully in the next week.
                  Thanks again
