KFS
  • ntbann
    • Jan 2012
    • 628
    KFS
    Anyone know of a way to clear the KFS setting on a Kyo printer? On the MFPs you can execute 520 to clear.
  • Tonerkiller
    • Oct 2012
    • 668
    Re: KFS
    I have not tried it, but my guess is that you would go to the web page and delete the info.
    • ntbann
      • Jan 2012
      • 628
      Re: KFS
      No. That doesnt work on the MFPs or the printers.
      • craigster
        • Apr 2016
        • 201
        Re: KFS
        I would go to KFS website delete the account then turn off remote services via command center but you have to have admin rights for the KFS website to delete the account. assuming the customer no longer wants KFS on there product.
        • Santander
          • May 2009
          • 768
          Re: KFS
          How about just turning remote services off either through the webpage or the systems menu?
          • ntbann
            • Jan 2012
            • 628
            Re: KFS
            All that does is either turn it off or on. It does not clear all of the KFS info from the machine. On MFPs when you run a 520 it clears all of the KFS access code so it can be re-entered. The printers have no 520.
            • FriendlyTech
              • Jan 2018
              • 30
              Re: KFS
              In KFS click the down arrow on the top right where it says devices (right beside help), click product downloads and download the device registration diagnostic tool, you can unregister a device using that.
              • tec966
                • Mar 2009
                • 42
                Re: KFS
                You have to "archive" the selected device
                • dschultz31
                  • Aug 2018
                  • 33
                  Re: KFS
                  Just recently had a Kyocera Printer that was offline and couldn't reset it, and the solution by the Technical support was to delete it from KFS and then reset to factory in the Command Center. Worked! The settings that were greyed out, came back and I was allowed to enter the URL and access code.
                  • Xer0615
                    • Jan 2019
                    • 48
                    Re: KFS
                    I thinkt he route mentioned above, of using DRDT to "deregister" the device would be a much smaller headache than doing a factory reset and having to do a fresh setup
                    • GeneOR95
                      • Feb 2018
                      • 161
                      Re: KFS
                      The only problem with using the DRD tool is that you must know the customer account 8 digit code the device was registered with to be able to enter it into the DRD tool. If the machine was originally entered by another dealer that could be problematic.
                      If this can be done without the existing code, please let me know here. That would be useful if I encounter a printer I need to reset.
                      • Xer0615
                        • Jan 2019
                        • 48
                        Re: KFS
                        True I didn't think about that. But If the machine is still registered via another company's access code, you're going to get an Error 403 when you attempt to register again.
                        • Assaf
                          • Jun 2009
                          • 59
                          Re: KFS
                          Yes you can , login the to browser using:
                          username: RSAdmin
                          password: RSAdmin
                          it will allow you to turn off the remote services, reboot the device after and you are good to go.
                          Kyocera fleet service specialist
