image failure M and K on TA-4052CI
  • taskalfaman
    • Nov 2009
    • 137
    [Electrical] image failure M and K on TA-4052CI
    dear All,
    has somebody had this fenomena in the past.
    what was the solution.
    tech already changed dk and Dv, high voltage pcb, and still the same negative result see sample in att.
    any positive feedback is welcome.
    best regards.
  • Kyo fan
    • Dec 2013
    • 368
    Re: image failure M and K on TA-4052CI
    Did that tech do all the adjustments from maintenance after replacing those parts?
    • RobertOB
      • Dec 2018
      • 26
      CHeck your wiring harness for the Belt
      • taskalfaman
        • Nov 2009
        • 137
        yes indeed , they went together for a second time and did all the sim over again with the same negative result.
        • JR2ALTA
          • Feb 2010
          • 2033
          I'd say there's some defect or contamination involving the transfer belt. I'm thinking inside the belt ass'y because the hazy spots aren't moving to other colors
            • 23010
            My suggestion is to swap the magenta with the yellow drum. I've done this before and was surprised to notice the problem gone. =^..^=
            • taskalfaman
              • Nov 2009
              • 137
              hi Guys,
              some feedback
              i went to the machine together with Kyocera HQ.
              they initialized machine with sim 20.
              possible reason electrical noise!
              power on machine => problem solved.
              we calibrated the machine properly.
              checked all values and problem is permanently solved.
              strange solution for strange problem
              • JR2ALTA
                • Feb 2010
                • 2033
                Crazy s#!t
                • GeneOR95
                  • Feb 2018
                  • 161
                  There is no Sim U020 on this machine. Was it possibly U002, "Set Factory Default"?
