scanning question
  • Intone
    • Apr 2015
    • 68
    [Error Code] scanning question
    Recently we have had quite a few clients have windows updates to there windows 10 computers and lose the scan to SMB ...is there any other way to connect for net work scanning to get around this ? ...just trying to exhaust all possibilities before we tell the customer it wont work ... one client has a Kyocera 300i ...another has the 2560 ...any help or suggestions are appreciated ...if there are no other setups available then so be it ...
    Thank you for your time ....Maurice
    Re: scanning question
    check the service portal.. there should be new firmware for the SMB1vs2 issue. Win10 has blocked SMB1
    • craigster
      • Apr 2016
      • 201
      I do believe that you can go into windows system and turn it back on.
      I recently asked the help desk at kyocera that question and he said you cant use smb 1 anymore on older models. Basically he said this is the way to get customers out of the old into the new. Google it and you might have your answer, its a big topic now
      • copiertec
        • Jan 2016
        • 2206
        On older machines, such as the ones you mention, FTP or email are you only viable options for scanning, due to the fact that Microsoft is turning off smbv1. I know it may be tempting to turn it back on, but I would not advise it because you will be opening up your PC to viruses that attack through SMB1 port.
          • 30238
          Use filezilla server
          • copier tech
            • 8156
            Update the firmware or you can simply re-enable SMB1 in Windows programs & features. Don't be put off with all the scaremongering about SMB v1 being a security risk, it's done OK for decades.
              Yes BUT the threats are just coming to the surface.. There was a industry report on here *1 yr?* that covered..smb1 and other network threats
              • ntbann
                • Jan 2012
                • 628
                Also if you turn SMB1 on your customers PC and they get hacked you are setting yourself up for a sweet lawsuit.
                • ntbann
                  • Jan 2012
                  • 628
                  Originally posted by kuby
                  Try is and see if it helps..
                  Go to windows control panel
                  Program and Features
                  On the left pane Click Turn Windows feature on / off
                  Find SMB client tab
                  check all on server and client option
                  apply and restart the computer.
                  your are done
                  You must not care about your customers security. How everyone forgets. Wanacry came in on SMB1.
                  • copier tech
                    • 8156
                    I only do this at the banks, government & military sites.........
                    My local church no fully locked down SMB v1 disabled.
                    • Intone
                      • Apr 2015
                      • 68
                      Never heard of this but will look into it ...thanks
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        One other option:
                        There's no need to run additional FTP server software unless the customer requires it.
                        You can FTP scan using an in house NAS or private cloud.
                        http://www.copytechnet.com/forums/co...tml#post694379
                        hhttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software.html#post694379
