Kyocera/ Utax Parts Compatibility
  • D Colour
    • Oct 2008
    • 217
    [Misc] Kyocera/ Utax Parts Compatibility
    Hi
    I wanted to confirm if Kyocera parts will fit with no issues into the Utax brand? Namely the fuser unit. I assume that it will, but want to be sure!
    We have a customer with a Utax 5555i (not supplied by us). It needs a fuser unit (FK-6307B). I know the developer units are normally different depending on the brand(Kyocera/Olivetti/Utax) for toner purposes.
    Will the fuser unit for the Kyocera 5501i fit with no problems? The plugs are going to be the same?
    James
    Everything that has a beginning, has an end.....
  • gwoodslive
    • Oct 2017
    • 5
    Re: Kyocera/ Utax Parts Compatibility
    yes Utax/Kyocera are exactly the same parts across the machine models. same parts, firmware etc. they just have different model names.
    the attached PDF will help you match the corresponding Utax model to Kyocera.
