Kyocera M5526 Color Banding
  • gandolf67
    • Jan 2019
    • 4
    I am having an issue with a M5526 color copier. See attached image. It only does it in color mode. Black and white prints and copies fine. I have updated the firmware, installed new MPCB and tried a new Transfer belt. No change. I have a High Voltage PCB on order but it is on back order till 1/29. That is a red flag to me. I am leaning towards the High Voltage PCB as being the problem. Notice the lack of void edge. I visually checked everything I could as far as grounds, and this machine has a ton of them and I don't see anything out of the ordinary. Machine only has 7,000 clicks 1/3 are color. Any thoughts??
    • 22999
    Re: Kyocera M5526 Color Banding
    Pretty! Isn't it? What you're seeing is the HVT shutting down because of a high voltage short.
    One of your color developing units is probably arcing to it's respective drum. It's probably not black, if black images are unaffected. I cannot help you choose which color to try first, but you'll need to change both the developing unit and drum for the specific color. I suppose that you could order CMY developer units and (1) drum, then try swapping in units. That way you could conceivably get it fixed in one visit.
    So look at your sample image. The color that's shorting is usually the color that is least present in the heavy background. =^..^=
      BlackCat hits the homer AGAIN! I concur.. we see this on several different brands.. even in color laser printers!
      • gandolf67
        • Jan 2019
        • 4
        UPDATE
        I have replaced ALL drums and ALL developers, along with the transfer belt and main PCB, problem is still present. The HVPCB will be in Tuesday, it's my last hope. I will update after it's install.
        • Raymondd
          • Jan 2008
          • 108
          Originally posted by gandolf67
          UPDATE
          Any update on this? We have a FS6535cidn doing the same thing HV pwb did not rectify the problem (for us).
          • gandolf67
            • Jan 2019
            • 4
            Yes Black Cat was correct.
            Turned out to be the Cyan Drum unit. However I did have to replace the cyan, yellow, and magenta developers because they all became corrupt. (the developer looked black on all of them).
            Replace each drum individually and test. You will eventually find the drum that is causing the issue.
            Good Luck
            • Raymondd
              • Jan 2008
              • 108
              Good Luck
              Thanks for the response! Unfortunately we have change all drum and dv units to no avail. Waiting on a response from our rep...
              • JR2ALTA
                • Feb 2010
                • 2030
                I am impressed that responded so quickly. Not impressed that your last post was not corrected prior. You cost a guy time and money.
                • gandolf67
                  • Jan 2019
                  • 4
                  Thanks for the reply
                  Have a Great Day!!
                  • Raymondd
                    • Jan 2008
                    • 108
                    I just ran across this thread TODAY, check the start date of the thread.
