TASKalfa 6052ci - code for printing B&W and color
  • kuby
    • Oct 2007
    • 1409
    On TASKalfa can you use a job accounting code for B&W and one for color. I tried to set it up but does one or the other. Thanks
  • darry1322
    • Oct 2010
    • 817
    Re: TASKalfa 6052ci - code for printing B&W and color
    Job Accounting allows you to control usage of the machine. Each account you create allows you to determine if that account is allowed to print and/or copy in color. The code does not determine the output it just allows or rejects the usage. It also keeps track of the number of prints/scans/copies, etc.
    example:
    User1 is set up to allow full use of B&W and color
    User2 is limited to B&W only
    When User1 logs in they can make B&W or color copies
    When User2 logs in they can only print or copy in B&W.
    There are more options to allow or reject usage under the user creation section.
    • kuby
      • Oct 2007
      • 1409
      Use can use codes when you want to copy that allows B&W or color. There is not a way to make them input a code when printing that will make it print in B&W or color?
        i do believe that is called 'Print ID Codes' or sum such
          • 23009
          Close: "Job Accounting"
          • Santander
            • May 2009
            • 768
            Are you talking about copying or printing? If it is copying you can install Color Lock where you can default users to BW {Public Access} that is set for just BW and need to enter a code for color. If it is printing then you would need to use Job Accounting to set the PIN numbers, but it would require in your explanation one account for say John Doe with a PIN of XXXX for BW and a duplicate account for John Doe with a PIN of YYYY for color, I do not see what you gain by this as job accounting will report the number of BW prints and the number of prints in color. Do you or your customer think their users are going follow this procedure? I doubt it! We default all print drivers for color copiers/printers to BW and the user has to select color when setting up the print job if they want it and with Job Accounting enabled it will accurately report what is printed in BW and what is printed in color for each user. Since four or five years ago the print driver/machines will even correctly assign pages the proper category automatically. Example: user selects print in color but only one page out of the four contains color, the machine counts three black pages and increments the black count by three, and the color counter by one. If you and your customer are trying to control users behavior by using codes, I think you are barking up the wrong tree.
            • Ctl-Alt-Del
              • Jul 2006
              • 430
              Instruction are available in the Operator's Guide
              Chapter 9 - User Authentication and Accounting (User Login, Job Accounting)
                Ok.. knew it was something like that
