task alfa 3051ci jam 0131
  • n25an
    • Jul 2008
    • 1030
    I am getting this jam code... 131
    once a day... before I touched it...
    so I did the following
    I replaced the bypass...
    and since customer was reporting various jams...
    I replaced the lct clutch pack and the clutch pack for the paperfeed section...
    since then the code has continued usually in the morning around 10 am according to the event log...
    machine has close to a million prints....
    I am checking if anyone has faced this issue before...
    note customer does not use bypass...
    this is why its so strange...
    and as always any help is appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • n25an
    • Jul 2008
    • 1030
    Re: task alfa 3051ci jam 0131
    i am getting the
    Manual feed clutch (MPPFCL)
    Middle clutch (MCL)
    Registration clutch (RCL)
    i am also going to update firmware...
    i will let you guys know how it goes...
    • n25an
      • Jul 2008
      • 1030
      turns out issue was in bypass section...
      when machine turns on or comes out of sleep jam would show...
      the bypass assembly was changed but the actual table that the paper rests on is spring loaded and it was triggered...
      so it was snapped all the way to the top...
      so there was no space for paper...
      this triggered a jam state...
      you could open a right side door and close it and the jam would go away...
      but machine would be in error state and it would show up when machine came out of sleep or was restarted...
      my supervisor discovered the issue... and aligned the plate so that it was not triggered.....
        • 23007
        Interesting! Thanks for posting your results. =^..^=
