CS-2550 scanner not working
  • trailboss
    • Aug 2025
    [Misc] CS-2550 scanner not working
    hello,
    I click on the scanner button and it dont work and I click on the scanner function button and it also do not do anything. I was reading the password is 2500 and that dont work. I'm trying to setup so i can print to PC and i installed the print utility software. copystar CS-2550.
    thanks
    • 23010
    Re: CS-2550 scanner not working
    This will sound silly, but does it have the scan option card? If it doesn't have a Scan System (F) (with 2nd RJ45 jack) then you won't be scanning. And what is this Print-to-PC function? Is that like Print-To-File?
