Problem with TA2551ci strange printout ocasionally
  • drazen7777
    • Sep 2010
    • 40
    Hy to all
    I would like to ask you if someone had similar case to help me . Problem is that in 100 print jobs it prints 2-3 strange printouts (example in attachment)colour lines (all colour) and erased print in some parts. That happen when high volume of jobs is beeing printed , cca 1000 pages at once , MK a+ b was done cca 10000 prints ago , so if someone has dealt with same things please give me hint. Will try to replace transfer belt today to eliminate him.
    regards
    Drazen
    Technician -- a person who fixes the mistakes made by engineers.
  • taskalfaman
    • Nov 2009
    • 137
    Re: Problem with TA2551ci strange printout ocasionally
    try to change the drums @ the same time if not solved hvt under scanner.
    • Kyo fan
      • Dec 2013
      • 368
      I would clean the lasers 1st, and check the contacts drums and devs are making on the back side once pushed in.
      • drazen7777
        • Sep 2010
        • 40
        hy
        I already cleaned laser and drum and transfer contacts , i think it must be something electrical
          • 22999
          My guess is that the yellow developing unit is shorting to the yellow drum, via the developer spacers. Did you notice the complete lack of a yellow band? =^..^=
          • drazen7777
            • Sep 2010
            • 40
            Thanks, blue dev was shorting and was replaced, with blue drum. customer says that it was examples of yellow band but not visible on the attached example.
            Poslano sa mog SM-N960F koristeći Tapatalk
            • djs9164
              • Mar 2018
              • 79
              I had that same issue. It was the contact spring on the drum unit not making contact.
              Sent from my XT1635-01 using Tapatalk
