3500i missing options in service mode
  • docresources
    • Feb 2017
    • 7
    Have a 3500i that when you go into service mode u508 through u900 are missing. I have upgraded the firmware to the latest. Any help would be appreciated.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Re: 3500i missing options in service mode
    was it working before the update?
    what version did you use?
    any errors or power failure during process?
    • docresources
      • Feb 2017
      • 7
      They were missing before I upgraded. That's why I upgraded it.
      • copiertec
        • Jan 2016
        • 2231
        Have you tried a U021 (return to factory defaults)?
          • 22995
          Take a look at the manual. There are no simulations between U508 and U900. There's nothing to find.
          • docresources
            • Feb 2017
            • 7
            Well I'll be dipped in shit and called a turd lol, he's right. This is the first kyocera I have run across that doesn't have them. Ok so then how do you clear the fax dim.
              • 22995
              According to the fax setup instructions U600 ... hmmmm?
              • Santander
                • May 2009
                • 768
                Do you have a fax option Installed? If the unit does not have a fax board installed the sim modes 600 plus will not display as there is nothing for the unit to do. If a fax option is installed, I would try to reseat it, otherwise you have a bad fax board that the unit is not recognizing.
