M6026CDN asking for cyan toner
  • copier tech
    • 8164
    [Electrical] M6026CDN asking for cyan toner
    Hi all,
    I have a M6026CDN that shows toner empty, I fitted a new one the same issue.
    I have fitted a new dv unit this resolved the issue but the next day the fault returned.
    Am I looking at replacing the toner motor or hopper etc?
  • copier tech
    • 8164
    Re: M6026CDN asking for cyan toner
    Reading the parts manual, is there a separate toner motor for each colour, or does this come with the main drive?
    • copiertec
      • Jan 2016
      • 2207
      I believe they are separate but a pain in the ass as you have to strip down the entire unit. I see you have replaced the dev unit, that was my suggestion, have you input the new developing unit # into the mfp? Have you tried a different transfer belt? I have had those give me issues of not adding the toner.
      • copier tech
        • 8164
        • George J
          • 107
          +1 on the transfer belt not passing through the toner.
          • Gina82
            • Oct 2017
            • 98
            Check auger in transfer belt that is responsible for adding toner. These tend to break (plastic). In my experience, ours usually start with asking for yellow toner repeatedly. But I would go with transfer belt next.
