Falcon I changing paper sources while printing.
  • Jimbo1
    • Mar 2008
    • 845
    I have a Falcon I that will periodically change from 8 1/2 x 11 to 11 x 17 while printing and it doesn't stop or jam or misfeed it just prints the same thing on different size paper without altering the image at all.
    Thoughts?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • 23009
    You've probably already tested out the DP length sensor, but it may have an intermittent problem. Thats about the only thing that makes any sense, in that the machine doesn't jam. =^..^=
    • Jimbo1
      • Mar 2008
      • 845
      Yes but this is a print job, not a copy job. It may be the application causing it but can't be sure. it's not real critical just one of those little things if you can find the solution to helps keep a customer around later.
      Already quizzed them if their page length was over long.
      Cdr. William Riker
      • termacadon
        IT goofball
        • Oct 2008
        • 66
        There is a firmware parameter that you could change. I dont have my manual with me atm, but then again, im also not too familiar with the falcon 1. Which models are those?
        • Jimbo1
          • Mar 2008
          • 845
          The 2530,3530, or 4030.
          Cdr. William Riker
          • termacadon
            IT goofball
            • Oct 2008
            • 66
            Sorry... I know those models.
            Check parameter R1 (Auto cassette switching) in your technical manual for firmware parameters. I think the default is 0 which means it will not swap cassettes.
            and R2 (Default paper size)
            and R4 (Sets your default cassette)
            here is a link to download the manual. Its about 10mb
